Old 12-28-2008, 07:54 PM   #1
cstm68
cstm68's Avatar
towing with a 1/2 ton?
i have an 01 z71 1500 LT with a 5.3L vortec, is it a bad idea to tow a trailer with my 68 swb on it? i have a heavy duty aftermarked reciver if that makes any difference,
if i do tow with it it would be mostly highway driving once or twice a year?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 12-28-2008, 08:52 PM   #2
LowBow
Self Made Hundredaire
LowBow's Avatar
Re: towing with a 1/2 ton?
Is it the one in your sig with 6" of lift and 35's? The only thing I would check would be to make sure all your fluids are o.k., make sure you have a trans cooler, and maybe look into a programmer that you can set up for towing. I have an 03 z71 that I just towed my '72 with. No problems there, but it was only an hour drive.
LowBow is offline   Reply With Quote
Old 12-28-2008, 09:11 PM   #3
71swb4x4
71swb4x4's Avatar
Trailer brakes are an absolute must.
I would make sure you have a tranny cooler too, otherwise you should be good to go.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-28-2008, 09:34 PM   #4
LowBow
LowBow's Avatar
I never think about stuff like that! I never have to deal with snow or mountains.
Old 12-28-2008, 09:58 PM   #5
71swb4x4
71swb4x4's Avatar
It's not a snow or mountains thing. Sure, you can get a 1/2 ton stopped while pulling a car trailer with a full-size truck on it, but not it sure isn't stopping as well as it stops unloaded.
Imagine you are close to home, and a kid runs out in front of your truck. You want it to stop like you aren't pulling a trailer, which it can only do if it has properly operating trailer brakes.
Another situation, which has come up a couple times on this message board, is when you are minding your own business going down a hill and all of a sudden your trailer decides it's going to pass you. This isn't a deal where your trailer is coming all the way around, yet. Your trailer starts swaying back and forth because it is building up momentum that you can't decrease if the trailer doesn't have brakes. Your only option is to hit the gas and stay in front of it.
Trailer brakes just make good sense when towing. It's cheap to add to most new vehicles. If you are trailer shopping you can get a trailer with hydraulic brakes which don't need any controls in the tow vehicle.
Old 12-28-2008, 10:39 PM   #6
cstm68
cstm68's Avatar
yes it is the one with the 6'' lift and 35s,
the trailer has hydraulic brakes, but i was thinking about setting the truck up to use electric trailer brakes too, i am also adding ride right air bags in the rear,
since the truck has a 6'' lift do i need a drop hitch? 4'' or 6''? how far should the ball be from the ground? i thought it was 18'' but i cant remember?
Old 12-28-2008, 11:33 PM   #7
truckdude239
truckdude239's Avatar
low enough the tailor sets evenly
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-29-2008, 10:41 AM   #8
71swb4x4
71swb4x4's Avatar
I have heard that the standard height is 15" from the ground, but like David says it should be whatever it takes to make the trailer level.
