Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-28-2008, 09:52 PM   #1
69trk
69trk's Avatar
front sway bar
should i keep my front sway bar on or not? I think that it might help with traction and frame twisting, but i'm trying to eliminate front end weight.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-28-2008, 11:01 PM   #2
narleycarley
Re: front sway bar
if all you do is go straight, sure... chunk it.
narleycarley is offline   Reply With Quote
Old 01-05-2009, 08:55 AM   #3
djracer
djracer's Avatar
Re: front sway bar
not counting the weight I bet if you just unhook it from the control arms it will help your weight transfer. It depends how much you drive it on the street but it should be a little faster on the track without it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
