Old 12-30-2008, 04:19 AM   #1
Barrnone
Barrnone's Avatar
Odd spark plug wear
I am hoping some of you have seen this kind of pattern before and can explain to me where I should be looking for a cause. This is a 350 TBI motor that has gradually started to get intermittent misses, getting worse over time. I pulled the plugs and all 8 of them have a dark gray spot going down the insulator, some with deposits on the spot also. I have attached a couple photos to show what I am trying to describe. These plugs have almost exactly 10,000 miles on them. Thanks for any help.
72 Chevrolet C20 LWB Fleetside
89 Toyota Supra Turbo
87 Toyota Supra (DD)
95 Ford Thunderbird (4.6 V8)
95 Chevrolet Tahoe
Barrnone is offline   Reply With Quote
Old 12-30-2008, 04:53 AM   #2
Senator350
Senator350's Avatar
Re: Odd spark plug wear
increase the carburetor jet size slightly, take out some timing, or go to a colder plug.
from: http://www.dragstuff.com/techarticle...ark-plugs.html
RN U OVR
Senator350 is offline   Reply With Quote
Old 12-30-2008, 09:55 AM   #3
cdowns
cdowns's Avatar
TBI motors dont commonly have carbs
Old 12-30-2008, 09:59 AM   #4
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Go to a colder plug, CR43TS ac delco is the factory plug for TBI trucks, as stated above by senator back some timing out of it. On a TBI motor you have to unplug the "timing control module" which looks like a breaker, that is what controls the advance instead of a vac advance. Dead nuts zero timing is "ideal" per GM, but any place between 0 degrees, and 6 degrees after will work. Also make sure there is no exhaust leaks, with plugs like that a burnt valve is a possibilty. The deposits are cause by the wet fuel that lingers around the exh valve in the chamber. If you can burn that fuel, your problem will burn with it.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
