12-31-2008, 06:37 AM | #1 |
Help!?!? 2wheel to 4wheel drive conv.
Ok, here's my problem I bought this truck when the previous owner was mid-way through the project, all the 4x4 stuff is there except the 4x4 linkage and front driveshaft were not installed. I'm not worried about the driveshaft, I am however leery of cutting the floor board to install the 4x4 linkage since I am new to build"ing" so to speak. So if anyone out there has done this before please send me information and pictures of how to do this properly.
Thanks, -Jon |
12-31-2008, 09:26 AM | #2 |
Re: Help!?!? 2wheel to 4wheel drive conv.
1st:
Is the 4wd stuff from the same years (67-72,I assume) as your truck?So your cab is from a 2wd with the non-removable low center hump?If not,I`m not sure how it all fits under there.If it has the removebale hump it`s easy as locating the proper hump cover.If the transfer case isn`t one used in this series the shifter would be in a diferent place. Let us know more and we can suggest the best route to take.
01-02-2009, 01:51 AM | #3 |
Picture of my floorboard without the gas tank
01-02-2009, 09:11 AM | #4 |
Ok,I see the 4spd does fit.I don`t think I ever knew it would fit.The factory uses the high hump on all 4spds,even 2wd.
So...it`s all in except the shifter,right?I realixed I don`t have a 4spd 4wd here anymore to measure the holes.I do have a 4spd/NP 205 combination I can measure to see where the shifters are in relationship to each other.But,you can do that with what you have. Do you know if you have a NP205 transfer case?It will say so on an ID tag on the back of the case.They are iron and have a pto access plate just like on the transmission. Does anyone have a 4spd 4wd hump they can measure the hole locations on?
01-02-2009, 11:45 AM | #5 |
Post Whore
I can measure the location for my NP205 shifter in my 70 K5 this evening. It has a SM465 4 speed.
Will you be filling in your 4 speed shifter hole some? It is way oversized presently.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-02-2009, 02:39 PM | #6 |
homemade hole for referance on the 1971 red one, yellow is factory 1977 w/np203
01-03-2009, 12:21 AM | #7 |
Post Whore
Okay, I measured with my 4 speed in 2nd gear and the NP205 in 2Hi. From the 4 speed's shifter go 8 1/2" back and 2 1/2" over to the passenger side. Open that hole up enough so you can shift the t/c case shifter with a little extra clearance so you have no rubbing when offroading and the body is a little twisted.
01-03-2009, 12:35 AM | #8 | |
The pictures aren't the best; here's the information on the tag and case- New Process Gear Model 208 C ASSY. NO. 02 0893 SERIAL NO. 110 841 RATIO 261 SYRACUSE NY C-15085 |
01-03-2009, 01:10 AM | #9 |
01-03-2009, 09:47 AM | #10 |
Post Whore
I don't know if the 208 shifter is in the same location as the 205 which is what I measured - I'd get the shifter installed without the cover and do some measuring, then cut your hole to make sure you get it where it should be.
01-03-2009, 08:55 PM | #11 |
fun fun, I'm gonna work on it some more tomorrow just come down to going for it and hoping for the best Thanks!
01-03-2009, 09:12 PM | #12 |
good luck with your project. i am thinking abouth doing the same swap.
crap.... i hope i dont get banned for saying that!! |
01-04-2009, 04:17 AM | #13 |
Good news and bad...
The 208 isn't the strongest case in the world, but it will last a good while, and the 2.6-1 reduction will help with your taller gears. The SM465 bolted to it pretty much has to be a 32 spline late model unit, arguably the toughest manual trans to come on a 4x4(maybe less beef than the NV5600 $$$$6speed?). 32 spline NP205's, and most of the shiny aftermarket stuff require this trans (identify by round bolt pattern trans-transfer case adapter). This would usually have come with a hydraulic clutch, but looks like maybe they made something else? There should be a brace rod from the passenger side of the transfer case to the upper right bellhousing bolt, it helps prevent housing breakage. Crossmember mods might be needed, I have a vague memory of the front shaft from a 208 being too low, having interference issues...the front output should use a flange type double U-joint from a 93- suburban, or 89 down truck. And I don't think this does 'fit' the low hump, it looks like despite the huge hole, they had to bend the edges up to clear.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars Last edited by 68K20 x Drill; 01-04-2009 at 04:23 AM. |
01-04-2009, 10:16 AM | #14 |
Since you have a transfer case that didn`t come in these trucks the hole for the shifter will be located in a different place.The NP208 is what came in the CUCV 1t & Blazer and serves it`s purpose.I`ve been tempted to suggest locating a floor section with high/removable hump and using that.You may help your floor some with that,you won`t have to deal with the previous owner`s hole,and you will have a removable cover that will make it so much easier to get your holes right as well as have proper access for any future servicing.The best hump would be a 4spd 2wd.They are most common and you`d have the one hole you need and you can put the t-case shifter in it`s custom location.I think you`ll thank yourself and will end up with a floor you can use an out-of-the-box floor mat or carpet.
Your floor section can come from any 4spd equipped truck/Blazer/Suburban,any 4wd,and any big block.Usually grease,oil,and location preserve this area from bad rust.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-04-2009 at 10:19 AM. |
01-05-2009, 05:12 AM | #15 |
Thanks for all the information guys! I kinda figured that after I read about the high hump I was gonna need one looks like a worth while investment... starting to take the rust/project a little more seriously, I think I'm going to go ahead with painting and lining the bed to remind myself of the goal of this truck, which is kinda changing as I continue with it. I think I want it too look a little nicer not quite show but at least slightly better than daily driver Anyways keep the comments and ideas coming loving the input, Thanks!
01-05-2009, 05:25 AM | #16 |
Some of the best things in life are free... or at least things ya bought a long time ago and found again; here are some of my buried treasures that are going in the truck
01-05-2009, 05:33 AM | #17 |
Rhino line it all and cut as needed. All the extra stuff is just drain holes for the mudd and water that will fill the cab.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
01-05-2009, 12:04 PM | #18 |
An NP208 transfercase shifter mounts to the body and has a rod that goes to the tcase to shift it. Your best bet would be to find a shifter from a late 80s to early 90s truck or blazer, mount it to your floor boardand then ajust the length of the control rod as needed.
02-08-2009, 05:38 AM | #19 |
Selling 2 tailgates... hurry there gonna go fast... one way or another; read
http://67-72chevytrucks.com/vboard/s...96#post3131296 |
Tags |
2 to 4x4, 2wheel to 4wheel, cutting, floorboard, metal fab |
