01-13-2009, 11:04 PM | #1 |
towing with 4.3
i am looking at towing with a 4.3 what can i do to get it ready it.ll be pulling a tandem car trailer with a truck on top
i know first person will say a 5.3 or 4.8 thanks
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
01-18-2009, 07:27 PM | #2 |
Re: towing with 4.3
5.3 or 4.8
really, i dont think there is much you can do to get ready, just be prepared to sit about about 50 mph or so, and dont push it too hard. keep the tranny out of overdrive.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
01-19-2009, 01:48 AM | #3 |
Sb 400 club
Re: towing with 4.3
Also want to consider that it is not the power that is most important it is the stopping and control.
with a well balanced trailer and brakes u should be all set. what is the 4.3 in and what are you towing on the trailer? Defiantly no OD as suggested above. Have fun winding the 4.3 up
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
01-20-2009, 07:50 AM | #4 |
Re: towing with 4.3
Towed many a thing on my 4.3 powered 400 body. Including gross overloads (10k on 7k trailer, bent the axle, hubcaps would pop off on corners, etc) and 87 chevy (talk about fighting the wind!).
1. Tow in D not OD if you have a 4 speed auto, or you'll be looking for a trans. 2. Be very sure the trailer has brakes and they work well with the controller (you do have the factory wiring and tow package right?). 3. 50mph max. 4. Remember that it's not a big block. If you pass anyone you're going too fast. 5. Load the truck on the trailer nose first to be sure that the weight is slightly forward. If the weight is in the back the trailer will try to lift the truck and your traction and handling will be shot. 6. 4 chains/straps minimum, and not the crappy 1" ones either. Nothing worse than having the truck come off the trailer. 7. Be sure that the hitch is locked on the ball. Your truck is light and will have a tendency to be whipped around by wind. if you feel the truck swaying apply the trailer brakes and slow down! And don't go that fast again!
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by D13; 01-20-2009 at 07:51 AM. |
01-20-2009, 10:35 AM | #5 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: towing with 4.3
I pulled my 72 shortbed home (400 miles) with my 06 reg. cab short bed with a v-6 at 70 m.p.h no problem. As long as you have trailer brakes you should be fine.
01-20-2009, 11:03 PM | #6 |
Re: towing with 4.3
If you are going to do this much, I would install a tranny cooler, besides all the stuff mentioned about the brakes. I have seen plenty of folks here to with a 4.3 (and tow a lot more than what they should). Although we are pretty flat landed here. I am not sure I would want to attmpt that on any high altitude or sharp long incline/decline roads thoguh with your load and a 4.3. But it''l do it.
I towed a truck (87ish C30 Flatbed, Big block) about 300 miles (tow bar) with my 92 C1500 (5 speed). The only real issue I had was a few washboard type roads and I was going a bit too fast, so it made my C1500 a bit jittery/slippery feeling in the back end. Although it was never a problem the braking without trailer brakes DEFINITELY requires you to plan your stopping WAY ahead of time. I am told it would be a lot easier with the 4.3 & automatic.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-20-2009 at 11:04 PM. |
