Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-14-2009, 04:44 PM   #1
old Chevy guy
old Chevy guy's Avatar
Blazer Buckets in s10?
Has anyone ever installed buckets from first generation blazer into an s 10,also first gen.What was involved? Did s 10's ever come with factory buckets?
old Chevy guy is offline   Reply With Quote
Old 01-14-2009, 08:40 PM   #2
corn
Re: Blazer Buckets in s10?
A friend of mine had one with buckets & console. It had a 4.3 so Id say early 90s S10.
corn is offline   Reply With Quote
Old 01-14-2009, 08:48 PM   #3
BarryB
BarryB's Avatar
Yes, theyll fit, I am pretty sure you'll need to drill holes for the inside tracks, but be sure to reinforce the floor where you bolt the seats too, at least use big fender washers on the bottom side.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-15-2009, 09:05 PM   #4
v8blaze
yea they should swap over, the outside bolts will line up from the bench but i too am pretty sure you will need to drill the inside bolt holes. I just swaped a pickup bench into my blazer that had buckets and it took maybe 15 minutes total
v8blaze is offline   Reply With Quote
Old 01-18-2009, 02:00 PM   #5
MotorHead Lon
MotorHead Lon's Avatar
I did this in my 87 S-10. The outer seat mounts bolt to the bench seeat studs. The only problem I found is the seats are closer toghether that way and a factory console wont fit.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 01-18-2009, 03:31 PM   #6
v8blaze
i dont see how that is possible. My blazer was only offered with buckets, and i recently took them out, and a stock s10 bench seat bolted right in and i have the inside track studs just sticking up under the seat. The stock console was a very tight fit, mine had rub marks in it from the seat belt covers digging into it. Espeically once your seats flatten down some and push out on the edges, as all older seats do, it makes it an even tighter fit.
