Old 01-17-2009, 02:31 PM   #1
CHUCK3167
53 chevy 3100
How does a 53 truck with the stock front end handle and is it safe to drive on the street.
CHUCK3167 is offline   Reply With Quote
Old 01-17-2009, 03:30 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 53 chevy 3100
They are safe as long as all the parts are there and in good condition. The draw back on a straight axle is bump steer. That's when the truck hits bumps or ripples in the road while going around a corner it will try to bump the front end of the truck toward the outer edge of the corner. Its not a big problem at slower speeds but its a bit thrilling at 60 mph. Idependent front ends help eliminate that issue, not 100% but its greatly reduced. My son drove a 59 with a straight axle all thru high school with no problems.
dwcsr is offline   Reply With Quote
Old 01-17-2009, 07:44 PM   #3
CHUCK3167
Re: 53 chevy 3100
Thanks for the info
Old 01-17-2009, 08:52 PM   #4
1956cameo
1956cameo's Avatar
Re: 53 chevy 3100
I drive my 54 3100 with the old I beam suspension everywhere without a problem. Granted it does get a little nerve racking at speeds over 60 mph. Unless you are planning to drive your truck accross country alot or on highways at 70 mph alot I wouldnt worry about it. However you want to either re build the original components or check them out to make sure they are in good condition.
1956cameo is offline   Reply With Quote
Old 01-17-2009, 09:46 PM   #5
OrrieG
OrrieG's Avatar
Re: 53 chevy 3100
I drove my 59 for ten years with the stock straight axle, no problems, it just drove like an old truck!
OrrieG is offline   Reply With Quote
