Old 01-19-2009, 09:26 PM   #1
thorne101
4 inch lift questions
im looking at a 4in lift with springs, blocks and shocks, what all do i have to change or lengthen to do this, will i have to do anything with the drive shaft of the steering thanks for the help
thorne101 is offline   Reply With Quote
Old 01-20-2009, 12:39 AM   #2
Wreckless_71
Wreckless_71's Avatar
Re: 4 inch lift questions
Drop link is recommended... also i would recommend longer front brake lines. I have the stock ones on my project right now and I think I will end up switching to longer ones... besides that I think that's it.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 01-20-2009, 10:32 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
What year vehicle are you asking about. You will find there are no definites.
With a 4 inch lift your driveshafts should be fine, but occasionally there is an issue.
I did have an issue with the initial 4" lift I did on my 69 K20 - the front driveshaft was too short and I ended up having to add a Double Cardon Joint also.
Depending on the year of vehicle usually a raised steering arm is recommended to get your steering back to near stock. If you dealing with a 69 or older, you will need an adjustable drop drag link as a raised steering arm isn't available for the axle used in a 69 or older truck.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-20-2009, 11:58 AM   #4
Mudder
Mudder's Avatar
Most kits give you a bracket for lowering your brake lines. New stainless are pretty nice to have.
Mudder is offline   Reply With Quote
Old 01-20-2009, 03:32 PM   #5
Most lift kits include the steering arm you`d need and the steering absolutely needs addressed.I recommend a steering armover a drag link.The brake lines are a definate thing to address,too,but the relocation brackets that Mudder is talking about do the trick.I`ve never had to lengthen a ront driveshaft for 4".I suggest completing the lit and inspecting.When truckis sitting level the spline should have anout equal travel in and out.Take notice/mark the yoke/spline relation before and compare to after.
Old 01-20-2009, 09:22 PM   #6
duallyjams
duallyjams's Avatar
I would include a steering stabilizer.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-20-2009, 10:14 PM   #7
thorne101
it is a 72 thanks for all the good info im still looking into this to decide if this is the way i want to go yet or not thanks tony
Old 01-20-2009, 10:16 PM   #8
jkade
jkade's Avatar
Just get a steering arm and that is all you will need. I ran a 4" lift with just the arm for 4 years with no problems. Now if you are going to be flexing the suspension a lot I would do the front brake lines.
jkade is offline   Reply With Quote
Old 01-21-2009, 10:43 AM   #9
Dean
Dean's Avatar
I've got the brake hose part numbers if you are doing a K20.
Dean is offline   Reply With Quote
Old 01-22-2009, 09:33 PM   #10
Mike C
Mike C's Avatar
Skip the middle step and go ahead and get springs. The blocks stink. I bent both perches on my axle housing and had all sorts of wheel hop issues. Save a little more now, and only have to do job once.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-23-2009, 01:44 PM   #11
shakedown96
shakedown96's Avatar
I am doing the same thing with my 71 K10 I was looking at these:
http://www.ntwonline.com/67-72_GM_Su...cials_C782.cfm
using the top one and not using the blocks but using this:
http://www.offroaddesign.com/catalog/shacklekit.htm
it is the best in my opinon if your going to use the truck.
shakedown96 is offline   Reply With Quote
Old 01-24-2009, 02:01 AM   #12
xbanone
xbanone's Avatar
I always wonder who manufactures those NTW "suspension specials", anyone know?
xbanone is offline   Reply With Quote
Old 01-26-2009, 10:47 PM   #13
72chevyk10
I built it
72chevyk10's Avatar
my '72 didnt need the longer brake lines but probly would under heavy articulation(sp?)
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 01-27-2009, 08:00 AM   #14
NYC-10
screamin eagle
NYC-10's Avatar
I just installed a 4" BDS lift kit,all spring.I got a new steering arm and ordered ss brake lines that are 4" longer.looks like the e-brake cables are a little tight,I may remove them
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 01-29-2009, 03:25 AM   #15
xbanone
xbanone's Avatar
How do you like the ride of the BDS set up? I hear rear springs ride rougher than blocks.
Old 01-29-2009, 09:17 AM   #16
NYC-10
screamin eagle
NYC-10's Avatar
Didn't drive it yet but I will let you know
SCREAMIN EAGLE
Old 02-09-2009, 05:37 AM   #17
76PasoGMC
Not to hijack this thread but are real life opinions on the different brands of lift. I am more concered with ride. Which 4" all spring kit rides the best?
76PasoGMC is offline   Reply With Quote
Old 02-09-2009, 06:23 AM   #18
Blocks don`t change the ride.You just have the same springs with a space between them and the axle.
Old 02-10-2009, 01:08 PM   #19
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I did a junkyard lift on my son's that came out to about 4"....maybe more.
First.....I went to the junkyard and got some 52" springs off the back of an 80's Chevy truck. I also got the front hangers for the rear springs.
Cost was about $50.
This is the rear suspension that I started with.
Joey~AP is offline   Reply With Quote
Old 02-10-2009, 01:16 PM   #20
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I removed the rear hanger and drilled the holes out to 7/16". I then took the hangers that I got from the junkyard and mounted them.
I used grade 8 7/16" hardware to replace the rivets.
Kind of makes a shackle flip.
The above is not the shackle angle that I left it at.
I wanted longer shackles....which they dont make for Chevy's cause of the reverse shackles, so I found a set of lowering shackles that worked just fine!
I did have to get new brakelines.
Old 02-10-2009, 01:23 PM   #21
Joey~AP
TexasBowhunter
Joey~AP's Avatar
For the front I used the 52" leafs from the rar of the junkyard Chevy.
THis gets a little tricky, because you have to move the front hangers, move the rear hangers and locate or build some 7-1/4" shackles.
Old springs compared to new springs....
Original location...
New location...
You can see the old hole location of where the rear spring hanger used to be. I think I moved it forward a little more than an inch.
Old 02-10-2009, 01:27 PM   #22
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Then I had to make some shackles...
Old 02-10-2009, 01:27 PM   #23
Russell
Professional Grade
Russell's Avatar
Well done on the lift! That truck will ride smoother and articulate better than any lift spring possibly could. And it is done safely, which is key!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-10-2009, 01:35 PM   #24
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I cleaned the springs up and poainted them. Also cut the overloads.
Front required longer brake lines, too.
Put in a Pro Comp 4" steerin hootus to correct the tie rod angle.
Almost finished product.
Old 02-10-2009, 01:44 PM   #25
Jtrux
I'm a poor spectator
Jtrux's Avatar
I think you should do a more in depth build thread on that, I bet you'll have a lot of people trying to look fo this for possible future builds.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
