Old 12-08-2002, 02:06 PM   #1
abwdvm
65 gmc stepside questions again
I have a gmc short step titled 65. It has rear leaf springs (should be coil) It was a rear end that I am trying to determine the year, etc.
The rear end: Counted the ratio, 3.54. Small tag on cover says 46 13 and below 3 54. So i have the ratio right. I measured the drums, 11 inches in diameter. 6 bolt axels. The rear springs have like 8 springs each. I am thinking someone swapped the rearend with a heavy duty one. Anyone have any thoghts on which one? Is this really a 65 gmc?
ABW
abwdvm is offline   Reply With Quote
Old 12-12-2002, 12:50 PM   #2
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
I am no expert by any means, but there should be indication of addition of leaf springs. Typically, unless the person had access to a car lift, the angles and room to work will leave non factory looking weld beads on the "added on " shackles and brackets. That being said, you might try posting this on the 67-72 board. There is A LOT more traffic there.
Ro
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 12-12-2002, 03:19 PM   #3
JJR
JJR's Avatar
Hollanders shows 65 GMC 1/2 tons came with either 7 or 10 leafs and were available with 3.54 gears. Your set-up is probably stock.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
