Old 01-22-2009, 06:26 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
valve spring question
i just got done regasketing a goodwrench 350 and i also added a new cam and valve springs. the springs are unused and are off of a set of world product s/r heads which are rated at .560 lift. is this spring too stiff for my application (im using the .420/.442 summit cam). would these spring damage the cam? i figure it wouldnt because s/r heads are supposed to replace factory heads. what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 01-22-2009, 11:28 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: valve spring question
You need to identify the spring rate, coil bind, open pressure and closed pressure - take this information and compare it to your cam card - that is the only way to know for sure
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
