Old 01-27-2009, 08:28 PM   #1
72c10lover16
72c10lover16's Avatar
transmission and gearing questions
I have a 72 c-10 350 4b with an automatic trans behind it and i also just bought a 69 chevy c-10 straight 6 with a 4 speed. I was hoping to put the 4 speed in my 72 eventually but i was wondering how that would work out. some people have told me the gearing may be to low im not sure though.
Please let me know anything you know
72c10lover16 is offline   Reply With Quote
Old 01-27-2009, 10:14 PM   #2
mrein3
mrein3's Avatar
Re: transmission and gearing questions
Both transmissions have the same final gear. 1:1. The only difference is that the auto will have some slip in the torque converter resulting in a slightly higher rpm on the highway when in high gear. That is why manuals get a bit better mileage than an auto with all other things on the truck equal.
The 4-speed may have a much lower 1st gear depending on the particular 4-speed you have.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-28-2009, 07:59 AM   #3
72c10lover16
so the swap should work fine. does it matter what rear end i have in it.
Old 01-28-2009, 09:34 AM   #4
mrein3
mrein3's Avatar
Switching from an auto to a straight stick in your truck, without changing rear end gears or tire size, will drop your highway RPMs slightly. The slight drop will come from not having a torque converter slipping like you have in your auto right now.
'72 Malibu hard top
Center City, MN
Old 01-28-2009, 05:06 PM   #5
72c10lover16
so when i go to swap them everything will function properly?
Old 01-28-2009, 05:32 PM   #6
cdowns
cdowns's Avatar
do lots of research on the swap such as changing crossmembers linkage etc// in my opinion a step backward
Old 01-28-2009, 06:02 PM   #7
Green Machine
Green Machine's Avatar
The 69 likely has a removable high hump floor pan over the transmission because of its height. Your 72 likely has the standard low hump that is part of the floor. If you swap the big 4 speed into the 72, you will have to cut out the floor pan and install the taller floor pan hump from the 69. You will need to cut a new shifter hole in the 69 pan because the V8 sits farther ahead than the 6 cylinder.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-28-2009, 07:58 PM   #8
72c10lover16
ok thanks for all the help. i figured that i can switch the crossmember from the 69 and put it on the 72. i think i can do that anyways. i didnt know about the v8 sitting up farther but now i do. will i have to get a different bell housing to put the 4 speed on the v8? also would i be able to put my automatic from my 72 into the 69? so that i can resell the 69 and get my money back
Old 01-28-2009, 09:11 PM   #9
lilred67
lilred67's Avatar
you can use the same bellhousing. I THINK you can use the same fly wheel and clutch set up.maybe someone will know for sure!!
lilred67 is offline   Reply With Quote
Old 01-28-2009, 11:16 PM   #10
72c10lover16
is there anything else i need to know for this swap? what about driveshafts? i should be able to put the 69 one in my 72 right. thats after i switch the trannys.
transmission
