Old 01-29-2009, 02:22 AM   #1
mnky30
mnky30's Avatar
00 chevy 3500 eletrical problems need help
my 2000 chevy 3500 work truck has no power at the heater fuse and the anti lock brake lite turns off and on when it wants and there is a buzzer that goes of every once and a while. any one every experince this and what was it. thanks
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 02-02-2009, 02:20 PM   #2
finch
finch's Avatar
Re: 00 chevy 3500 eletrical problems need help
sounds like maybe an intermittent ground or ABS sensor. or a combination of things. check out the ABS sensors located on each front hub. chek for corrosion or broken wires.
check the under hood fuses and any exposed wiring for damage, let us know what you find.
Andy...
'70 C/10 Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=298553
'71 K/20 Frame-off resto, SOLD!!!
http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12
'05 Silverado Z-71, CC SB, Daily Driver
finch is offline   Reply With Quote
Old 02-03-2009, 01:04 AM   #3
mnky30
mnky30's Avatar
i will check those out and let you know what i find. thanks
vinnie
Old 02-23-2009, 09:13 AM   #4
Houston54
There is a small ground wire on the rear passenger side of the engine that comes out of the harness and is secured to the rear of the block with a bolt. Disconnect the bolt, clean the surfaces and re-install. This solved the electrical issues I was having with my 2003 Sub. It may or may not help with your problem but it may be worth the effort.
Houston54 is offline   Reply With Quote
Old 03-06-2009, 12:46 PM   #5
mnky30
mnky30's Avatar
well i found the problem it was the ignition switch the orange wire coming out of the switch that powers fuse # 6-12-18-24 fuses was getting no power. replaced ignition switch and all works again. thanks for the help guys
vinnie
