Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-30-2009, 10:02 AM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up 8.8 Rear End that will mount up to a 1962 Chevy Pickup
Guys,
I have a Ford 8.8 Rear End that will mount up to a 1962 Chevy Pickup. She will bolt straight on! I used this on my truck before I changed to the 9 inch Ford Rear that I have now. Nodular iron.
The rear end is in good condition and has new brakes. The gear ratio was 3.08:1 Good road gear. Tight! No play in it. This came out of a police interceptor car. $100.00 green stamps! Includes everything you see in picture! Also will throw in the matching drive shaft in with it also. Buy her, slap her on, roast'em slap off! Well with a 3.08:1 you want be able to roast'em, but you will save gas!
Thanks,
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-03-2009, 11:47 PM   #2
joe231
joe231's Avatar
Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
posi?
CHEVY ONLY
Old 02-04-2009, 04:00 AM   #3
LILRED66
LILRED66's Avatar
I was miffed at 8.8, but now I see it is a blue oval, so I know why I didn't recognize the title. Sounds like a great deal, but I am afraid if I mix breeds my bowties will boycott me. Good luck with the sale.
LILRED66 is offline   Reply With Quote
Old 02-04-2009, 05:44 PM   #4
1Bad62Pro/Street
Unhappy Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
Originally Posted by joe231 View Post
posi?
Joe,
It's not a Posi Trac rear end. She's a one legger.
Old 02-04-2009, 06:15 PM   #5
1Bad62Pro/Street
Thumbs up Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
Yea I should of stated that in the title. Yea....She's a Ford 8.8! See.... I can explain. Well....... uh....... Well she was free!
My Original rear end was wore out and this was a perfect fit for the time. Well I quess I can say I have a mix-breed! A mutt! But you know..... She's my mutt; and by gosh I love that ole truck! Ha Ha.
She only has a Ford Mustang IFS, and a Ford Rear End.
But....... Don't you just love seeing those Ford Trucks with Chevy Engines in them!!!!!! It's like they know better!!
Old 02-04-2009, 07:16 PM   #6
joe231
joe231's Avatar
hmmm.....thought all cop cars were posi....
CHEVY ONLY
Old 02-04-2009, 08:56 PM   #7
1Bad62Pro/Street
I asked my father and he thinks it was a 1985 Ford LTD Crown Victoria.
Mid 80's....
Some were posi, and some were not.
Some had disk brakes, and some had drums.
My rear end has Drum Brakes.
Some had bigger brakes as well. Not an expert, but just have alot of Ford Buddies! Sorry, I still show my CHEVY PRIDE!
Mustangs were also different.
Depending on Ford/Chevy/Dodge
http://en.wikipedia.org/wiki/Ford_Cr...ce_Interceptor
http://en.wikipedia.org/wiki/Ford_LTD_Crown_Victoria
Old 02-05-2009, 02:02 AM   #8
LILRED66
LILRED66's Avatar
Good stuff...thanks for sharing.
Old 02-05-2009, 07:02 AM   #9
1Bad62Pro/Street
History
Ford began using the 8.8" axle in Rangers circa 1986 on "incomplete vehicles" aka "chassis
cabs", but the 8.8" axles only became common in Rangers with the
introduction of the 4.0L V6 in mid-1990. It began appearing in Explorers (and Mazda's Navajo
twin) in 1991. It has also been used in 4.0L Aerostars (2wd ONLY, the 4.0 AWD Aerostars,
strangely, are equipped with the 7.5" axle), From mid'84-up F-150 (Except for 5.4liter "Lightnings
and Some 4x4 Supercabs which are equipped with the heavier-duty 9.75" rear axle) '84-1/2 on
Full-size Broncos, and E-150 Econoline vans.
The 8.8 is also used in other Ford products such as Mustangs, Thunderbirds ("solid axle" '87-88
with 2.3 turbo engine and 5.0 "Sport" models), Crown Victorias and their equivelent Mercury and
Lincoln products. However, because of their different suspensions, they make undesirable
choices for swapping into a Ranger (unless you're looking to also swap to a four-link rear
suspension for airbags and such).
An IRS version also appeared in the '89-97 Thunderbird, Mercury Cougar, (Though there is also
a 7.5" IRS in some V6 cars), the Lincoln Mark VIII and finally
a very similar IRS suspension was adapted for the Mustang Cobra.
A wide range of gear ratios is available, from 3.08's up to 5.13's. An equally wide array of
differentials is also available from open carriers to limited slips to lockers and spools.
8.8" axles can have either 28-spline or 31-spline axles.
All car applications use 28-spline axles, all truck applications use 31-spline axles.
axle shafts EXCEPT Rangers, which use 28-spline axles, however even Exceptions have
Exceptions, FX4 Rangers 99-current with 4.10 or 4.56 axle ratios are built with 31-spline axles.
Gear sets are interchangeable between axles, regardless of the spline count. Differentials,
however, are not.
Old 02-07-2009, 09:33 PM   #10
1Bad62Pro/Street
I measured the rear today 54 1/2.
I had 15X10 Cragers and Hides on them when I had her on my truck before the 9 was shoe horned.
Old 06-05-2009, 05:57 PM   #11
1Bad62Pro/Street
Exclamation Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
ttt
Old 08-01-2009, 02:00 PM   #12
1Bad62Pro/Street
TTT
This post had a few spider webs on it.......
So I bumped her back up.
Anyone?????????
Fish ain't bit'in
Well maybe somebody is in need of a good rear end.......
She is just waiting the be snatched up.....
Old 08-14-2009, 07:58 PM   #13
blue64
blue64's Avatar
chevy bolt pattern or ford?
blue64 is offline   Reply With Quote
Old 08-14-2009, 09:16 PM   #14
1Bad62Pro/Street
She's all Ford 5 lug Bud.
Old 02-12-2010, 08:14 PM   #15
1Bad62Pro/Street
TTT.
Any interests?
Old 03-06-2010, 04:04 AM   #16
63 extreme low
63 extreme low's Avatar
Damn, wish you weren't so far away!
1963 Big Back window short fleet
63 extreme low is offline   Reply With Quote
Old 03-06-2010, 09:19 AM   #17
1Bad62Pro/Street
See...
That's the thing.
I have alot of good stuff to sell, but it cost to much to ship.
Which you could not ship this, but you get what I mean.
Just tears me slap up.
Oh well....
Old 03-06-2010, 01:36 PM   #18
63 extreme low
What all are you selling? May be worth the drive!
Old 03-06-2010, 10:17 PM   #19
1Bad62Pro/Street
Just a few stuff Ha Ha:
STEVE’S AUTO STREET ROD SHOP
142 Manville Dr
Kings Mountain, NC 28086
(704) 734-0269
http://67-72chevytrucks.com/vboard/s...d.php?t=351000
steves_auto_street_rod_shop@hotmail.com
60-66 chevy under seat jack holders
http://67-72chevytrucks.com/vboard/s...d.php?t=349419
"1962 Chevy C-10 Stepside Stock Gas Tank"
http://67-72chevytrucks.com/vboard/s...d.php?t=355704
1960-1964 rebuilt 1/2 ton 3 speed transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=349416
1960-1962 Chevy C-10 Spare Tire Holder
http://67-72chevytrucks.com/vboard/s...d.php?t=349422
1962 Chevy C-10 1/2 Ton Rear Brake Drums with Shoes
http://67-72chevytrucks.com/vboard/s...d.php?t=349423
(2) KELLY CHARGER steel belted radial tires P295/50R15
mounted on 15X10 Cragar S/S Super Sport Wheels For Sale
http://67-72chevytrucks.com/vboard/s...d.php?t=371197
(2) Michelin Sport XGT P245/60VR14 Tires
mounted on 14x8 Rocket Racing 5 Spoke Spinner Wheels
http://67-72chevytrucks.com/vboard/s...d.php?t=371199
'69-70 Chevy C-10 LS9 350 Engine Parts
http://67-72chevytrucks.com/vboard/s...d.php?t=358698
1980--84 chevy 305 heads, cast # 14014416
http://67-72chevytrucks.com/vboard/s...34#post3843934
"1973 Chevrolet Nova", DOORS/BUMPERS/QUARTER GLASS/GRILLE/ETC
http://z3.invisionfree.com/Shadyside...showtopic=9099
1973 Chevy Nova additional Parts For Sale, L & R Quater Glass W/ Regulators, Doors
http://z3.invisionfree.com/Shadyside...showtopic=9551
Ford Stuff:
351 WINDSOR "Police Interceptor" HEADS
HEAD CASTING #: D9OE-AB 1.840 INT 1.500
http://z3.invisionfree.com/Shadyside...showtopic=9421
FORD 351 WINDSOR "Police Interceptor" ENGINE
BLOCK CASTING #: D9AE-6015-ED-18
http://z3.invisionfree.com/Shadyside...showtopic=8583
1976 MUSTANG II MISC PARTS
TAKE A GANDER INSIDE
http://z3.invisionfree.com/Shadyside...showtopic=9433
1976 FORD MUSTANG II
V6 4 SPEED TRANSMISSION
http://z3.invisionfree.com/Shadyside...showtopic=9098
1964 FORD FALCON FUTURA COMPLETE STAINLESS TRIM
http://z3.invisionfree.com/Shadyside...showtopic=9097
Ford 8.8 Rear End Differential
That will mount up to a '62 Chevy Pickup
http://z3.invisionfree.com/Shadyside...showtopic=9420
1975 Ford F-100 Pickup Truck Parts
L & R Door Hinges, Door, Bumpers Etc.
http://z3.invisionfree.com/Shadyside...showtopic=9552
7 hours 35 mins
http://maps.google.com/maps?f=d&sour...09&ie=UTF8&z=7
Old 03-07-2010, 01:18 AM   #20
63 extreme low
I would love to have the rear axle and those cragars just don't want to drive seven hours. Wanna come up and have a beer?
Old 03-12-2010, 09:21 PM   #21
aboz
aboz's Avatar
Hey 1Bad, how can I adapt my 6 lug Ralley rims to your Ford 5 lug axle? Is there an adaptor made? I'd love to put a 3.08 in my '63
ABOZ
aboz is offline   Reply With Quote
Old 03-12-2010, 09:50 PM   #22
1Bad62Pro/Street
Yep.
There are several company's that sell the adapters out there bud.
Here is one:
http://adaptitusa.com/5x135to6x135wheeladapter.aspx
http://www.ezaccessory.com/Articles.asp?ID=136
Thanks,
Old 03-13-2010, 10:41 AM   #23
1Bad62Pro/Street
Talking Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
Don't forget Bud,
I have those Cragers still for Sale.
I used to have them on that rear end.
12" Section
15"X10"
10 1/2 Tread
3 3/4 Back Spacing
4 1/2" & 4 3/4" & 5" Bolt Center
Last edited by 1Bad62Pro/Street; 03-13-2010 at 10:46 AM. Reason: http://public.bay.livefilestore.com/y1pQljgne9PismXw6uoDNMLfzGABpYVAGOWY1jeiFmLzS3Wt29BCtW0kteRYMtjHdijjXVkH-_SNdvLz3c0tPXrnA
Old 05-19-2010, 03:09 PM   #24
1Bad62Pro/Street
Arrow Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
Old 02-14-2012, 08:50 PM   #25
1Bad62Pro/Street
