01-31-2009, 12:56 PM | #1 |
Speedo calibration question...need help!
I'm posting this to help a co-worker. He has a mid 80's s-10 he has put a v8 in. He is trying to get the speedo to work correctly. It has a th350, 3.23 gears , 26 in tall tires, drive gear has 7 teeth and the new driven gear has 22 teeth (gray). The speedo is still 10-12 mph fast. What does he need to do to correct the problem?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
01-31-2009, 01:32 PM | #2 |
Trucks N Tranzams
Re: Speedo calibration question...need help!
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
01-31-2009, 02:45 PM | #3 |
I used this link before I posted and came up with 17.12 # of driven teeth. used this equation # Drive Teeth X Axle Ratio X Tire Rev. per Mile = # Driven Teeth
1001
01-31-2009, 02:47 PM | #4 |
He changed the driven gear from a 19 tooth to a 22 tooth gear. That's what a local trans shop said to do. It was orignally was about 30 to 40 mph fast and now its only 12-15 fast.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT Last edited by silvereagle07; 01-31-2009 at 02:55 PM. Reason: don't know |
01-31-2009, 07:58 PM | #5 |
BAD BOW-Silverado XST
He needs 8 driven and 20 driven gears. Driven ratio = 20.023. The speed will be almost dead accurate if he has a locking torque converter.
10 driven and 25 driven = 25.029 The top combo works the best. |
02-06-2009, 05:39 PM | #6 |
I agree with the above. Change the drive gear. It's really easy, only takes about 30 mins.
02-06-2009, 11:31 PM | #7 |
Thanks guys!
02-09-2009, 10:57 AM | #8 |
He has a 7 drive and 21 driven non locking torque convetor th 350. Does he need anything different w nonlocking?
02-09-2009, 11:56 PM | #9 |
No, he'll run ~200-300 RPMs higher to keep the speed indicated. Maybe more depending on the converter slippage.
