Old 02-04-2009, 09:16 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Drilling through carpet
What is the best way to drill small holes through carpet without snagging the carpet??
1971ChevyTruck is offline   Reply With Quote
Old 02-04-2009, 09:21 PM   #2
Security guy
Security guy's Avatar
Re: Drilling through carpet
I've always took a sharp razor blade and cut a small 'x' into the carpet where the bolt will come up through. I don't think you want to run a drill bit through the carpet. That could cause some problems.
Security guy is offline   Reply With Quote
Old 02-04-2009, 09:22 PM   #3
Skirkpat
Skirkpat's Avatar
What are you trying to do ? I would not "drill" carpet...if you are putting holes in the metal below, take the carpet out / pull it back...If you are trying to put holes in the carpet for wiring or something, I always get a large nail red hot and poke it through, that way it keeps it from un raveling around the hole.
Skirkpat is offline   Reply With Quote
Old 02-04-2009, 09:36 PM   #4
kyull67
kyull67's Avatar
^yeah I've found that burning a hole with a rod or nail works really well, unless it's somewhere noticable.
kyull67 is offline   Reply With Quote
Old 02-04-2009, 09:51 PM   #5
1971ChevyTruck
I need to drill small holes for the Lokar shifter boot cover and the door sill covers. The problem is I can't pull the carpet back around the shifter since it's already mounted. So I might try to use a soldering iron point to burn holes or something. I had heard if you reverse the drill that it might wear a hole with out snagging the carpet. Just looking for some good ideas.
Old 02-04-2009, 09:55 PM   #6
blakeaz33
blakeaz33's Avatar
I just put new carpet in my truck and had to drill holes for the the screws for the new door sill plates - I put masking tape over the carpet and drilled through the carpet with a sharp 3/16 bit and didn't have any problems snagging the new carpet.
blakeaz33 is offline   Reply With Quote
Old 02-04-2009, 09:58 PM   #7
1971ChevyTruck
Masking tape might just work...I might try that
Old 02-04-2009, 10:00 PM   #8
blakeaz33
blakeaz33's Avatar
Burning the holes like you mention sounds like a good idea - if I did it again I would heat up a narrow center punch I have with a propane torch and melt the holes through the carpet then drill. The way I did it worked fine - I postioned the door sills drilled a hole, I think the tape may have helped and I had a lot off pressure on the area I was drilling so that may have helped to eliminate any snagging.
Old 02-04-2009, 11:51 PM   #9
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
You can also cut the "x" in the carpet & place a piece of tubing into the x thats bigger than the hole to be drilled. Drill down through the space created by the tubing. Remove tubing & voila.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 02-05-2009, 12:02 AM   #10
cdowns
cdowns's Avatar
i've always used hole punches// available at hardeware stores sears cfart stores and online thru leathercraft suppliers
Old 02-05-2009, 12:03 AM   #11
cdowns
cdowns's Avatar
i've always used hole punches to make holes in carpet// available at hardeware stores sears cfart stores and online thru leathercraft suppliers
Old 02-05-2009, 12:06 AM   #12
Green Machine
Green Machine's Avatar
Pencil tip soldering iron works great for me, stinks like H**L, but gets the job done fast.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-05-2009, 02:21 AM   #13
frostie_122
drill in reverse for a bit and then drill through. shouldn't snag.
frostie_122 is offline   Reply With Quote
Old 02-05-2009, 06:44 AM   #14
GMC Jim
GMC Jim's Avatar
Several years ago, I had to install plug in receptcales on a carpeted wall. ( The carpet extended about 4 feet from the floow with a molding on top of carpet/wall.) Used a pencil tip soldering iron; worked great to 'burn' in the mounting holes...Worked great !!
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 02-05-2009, 07:22 AM   #15
Woody
Another option is to take a small piece of tubing and sharpen the tip. Chuck it in the drill and use it to drill thru the carpet.
But I like the idea of the hot soldering iron to burn a small hole.
Woody is offline   Reply With Quote
Old 02-05-2009, 04:34 PM   #16
adpostel
New Member
Originally Posted by security guy View Post
i've always took a sharp razor blade and cut a small 'x' into the carpet where the bolt will come up through. I don't think you want to run a drill bit through the carpet. That could cause some problems.
ditto!!
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 02-05-2009, 07:29 PM   #17
bigsnookmaster
bigsnookmaster's Avatar
Sodering iron works great for me!
bigsnookmaster is offline   Reply With Quote
Old 02-05-2009, 07:30 PM   #18
bigsnookmaster
Oops, Soldering
