Old 02-06-2009, 07:38 PM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
Q-Jet filters
Where's a good place to go grab some q-jet fuel filters? I didn't bother to try and explain my truck to the autozone guy today while looking for the 3/8 in. filter I needed (that wasn't there).
"If I look up a 1969 truck on the computer, is it going to show what you need?"
"No, probably not"
Need to replace both before I bother driving it a long distance again.
texanidiot25 is offline   Reply With Quote
Old 02-06-2009, 07:54 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Q-Jet filters
I just use the stock short round paper filter. I got mine at AZ yesterday. I probably should add another in line though.
sjarrett71 is offline   Reply With Quote
Old 02-06-2009, 08:17 PM   #3
texanidiot25
Eat My Rust
Re: Q-Jet filters
It's a good idea. Problem with the q-Jet filters is when their clogged, the fuel pressure pushes the filter off the carb to allow gas to bypass the filter. Not the best for the carb to say the least..
Old 02-06-2009, 08:33 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Q-Jet filters
Originally Posted by texanidiot25 View Post
..."If I look up a 1969 truck on the computer, is it going to show what you need?"
"No, probably not"...
It should.
I just go to the back of local autozone and check where all the filters are kept along the wall and get what I need. I use one under the cab between the tank and fuel pump and the one in the carb.
http://www.autozone.com/N,14900540//...eResultSet.htm
68gmsee is offline   Reply With Quote
Old 02-06-2009, 08:34 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Q-Jet filters
Like they said.Use an inline on and a carb one.They usually hang on the wall and you may only find the paper ones there but the counter guy should be able to help also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-06-2009, 08:37 PM   #6
texanidiot25
Eat My Rust
Re: Q-Jet filters
My motor isn't an original '69 motor, and god knows what my Q-Jet carb came with. I loose hope with every autozone because I can't just give straight part name (I've tried, have fun ordering an alternator) with out having to research a fake car to tell them that I own to get the parts I need.
They didn't carry my 3/8in fuel line filter either. Which is where my problems started today. When I go back up around that area I'll see, u nless my dad grabs on tonight.
Old 02-06-2009, 08:43 PM   #7
cdowns
cdowns's Avatar
Re: Q-Jet filters
i've always found them in the autoparts stores hanging on hooks in the fuel filter section
Old 02-06-2009, 10:15 PM   #8
texanidiot25
Eat My Rust
Re: Q-Jet filters
Thanks.. O'Reily's saved me tonight, had both filters I needed..
Got the parts # saved so, it's all good.
