02-09-2009, 01:34 PM | #1 |
Java Mechanic
2004 Gauge "recal" question
Reposting verbatim for a friend in a different forum:
======================================== GM has extended the warranty on these, and I need to get mine fixed. I have heard that all they do is reconnect some wires behind the gauges. I called the dealer and they say they have to check the numbers to see if they have to do the wire thing or swap gauge clusters. The problem is I have a Regency conversion pickup with custom gauges. I don't want them to swap these out for the stock ones. Has anyone gone to the dealer for this? What has been your experience?
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
02-09-2009, 05:40 PM | #2 |
Re: 2004 Gauge "recal" question
as long as the truck came from the dealer with these guages installed then they will replace with the same guages. I never heard of doing a "re-wiring" thing. what they do is perform a "sweep test" and if the cluster fails then they replace and reprogram the cluster set
This recall is a 7 year 70 thousand mile extended warranty for 2003-2004 fullsize trucks and suv`s only. I work for an extended care warranty company so we do see these alot!!!
1967custom Last edited by michael bustamante; 02-09-2009 at 05:42 PM. |
02-10-2009, 04:58 AM | #3 |
i had this done 3 times in about 1 yr to my 2004(all under warranty), i am pretty sure they changed the whole cluster all 3 times. it only took a few hours each time.joe
1992 Jeep Cherokee 4.0 AUTO 1972 C10 350/350 1971 C1500 350/350 1970 C20 396/400 |
02-10-2009, 07:44 AM | #4 |
Java Mechanic
Thanks Y'all -- I passed the info on.
