Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-25-2009, 03:46 PM   #1
low900rr
Project 69.........2wd to 4wd
Ok so this is a 69 I got a from a friend. Just a few pics from when we picked it up. I picked it up with no suspension under it, got it home and made it a roller to get in the garage. In one pic you will see my bodyless K5, thats all the running gear im using for the 69. Dana 60 front, 14 bolt rear, th400/205, 44's and a nice 383 stroker motor I have on a stand ready to go in. I just got my fgb52 kit today from DIY4x so im ready to get going on the 4x4 conversion. The body is from georgia but apparently had been leaking into the cowl and under the dash is rotted pretty bad, sucks cause the rest of the truck isnt too bad. I just picked some new body tools to help out with the body. Heres a few pics of some of the work ive done so far, I should have some updates tommorow with the axle and springs under the front of the truck.
low900rr is offline   Reply With Quote
Old 02-25-2009, 04:41 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project 69.........2wd to 4wd
looks like a good start...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-25-2009, 05:02 PM   #3
67-72crazy
67-72crazy's Avatar
great starting point.
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 02-26-2009, 08:43 PM   #4
low900rr
got the front springs in it today.............didnt put the 60 under it yet cause the truck wont fit in the garage with the cab on.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
Old 02-26-2009, 09:18 PM   #5
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Signing on for the Build, That willl be an awesome Stepper...............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 02-26-2009, 09:34 PM   #6
115-K10
115-K10's Avatar
Love the front spring/radiator support mount. Who makes them?
The chum Bucket - SWB K10 Restoration - http://67-72chevytrucks.com/vboard/s...d.php?t=329775
1971 SS454 Monte http://www.hemmings.com/mus/stories/...feature14.html
1970 - Monte Carlo Convertible, LS6, L89, M22 Build
http://www.firstgenmc.com/ubbthreads...=360236&page=1
1970-SS454 Tripe Black - Barn Find
http://www.firstgenerationmontecarlo...=421201&page=1
115-K10 is offline   Reply With Quote
Old 02-26-2009, 09:37 PM   #7
low900rr
diy4x.com
My builds
and the new 66
Old 03-01-2009, 10:45 PM   #8
arkracing
Weekend Warrior
What's the plan for converting the rear? Is this a GMC chassis or a Chevy - I know the GMC would have been leaf's in the rear making it easier to convert.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-02-2009, 12:11 PM   #9
low900rr
its a trailing arm rear.....gonna have to come up with a way to get some leafs in back. Ive read that the back of the 2wd frames are wider??
My builds
and the new 66
Old 03-05-2009, 08:06 PM   #10
jpholman
I am in the same boat as you. I need a solution to adding rear leaf springs. I know that stock 73-87 hangers can be made to work, but if there is anything else that would work easier Id like to know. anymore progress on yours?
jpholman is offline   Reply With Quote
Old 03-05-2009, 09:32 PM   #11
low900rr
Still welding more sheet metal on the cab, gotta get the cab all squared away then im gonna pull it off the frame. Once the cab comes off the frame ill work on getting the rear suspension done. I got a good game plan on doing it and will post pics of it when im done.
My builds
and the new 66
Old 03-05-2009, 10:03 PM   #12
BIG HEAD
that's an 8 inch lift rear 52' spring in the front. if that same set up was used in a 4x4 frame any idea how much lift that would give you?
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 03-05-2009, 11:03 PM   #13
low900rr
yes its an 8" rear.........2wd or 4wd frame this setup will net about 12" up front.
My builds
and the new 66
Old 03-05-2009, 11:10 PM   #14
BIG HEAD
thanks for the info. i was thinking six over the 8 inch spring, but it's about 4?
Old 03-05-2009, 11:22 PM   #15
low900rr
yep roughly 4"
My builds
and the new 66
Old 03-05-2009, 11:29 PM   #16
BIG HEAD
a friend of mine just picked up an 85 crew cab 2wd and i get the job of converting it to 4wd with 18 inches of lift.
Old 04-30-2009, 04:19 PM   #17
low900rr
http://67-72chevytrucks.com/vboard/s...=1#post3286528
My builds
and the new 66
Old 03-11-2012, 11:31 PM   #18
dme922
dme922's Avatar
I am working on a 71 gmc 2wd to 4wd project and your project seems to be the fix to my issues. Was wandering how you ended up doing the rear conversion. My gmc does have leafs and i was looking into buying a diy4x shackle flip for the rear and use the same as you did in the front. Please any help is appreciated.
dme922 is offline   Reply With Quote
