Old 02-28-2009, 11:05 PM   #1
BFRO$TY
Z'd frame?
Okay so me and the pops just got the 71 c10 on bags and were not satisfied. we did it with the stock a-arms, but with 3 inch drop spindals and we were really hopin to lay frame. Well i had the idea of "z"ing the frame but i'm not so sure as what to do exactly. It would be great if some of you guys could help us lay frame.
Thanks,
BFRO$TY
BFRO$TY is offline   Reply With Quote
Old 02-28-2009, 11:18 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Z'd frame?
Are you planning on Z'ing the front & the rear, or are you going to notch the rear
I Z'd the rear of my truck, but not enough to lay frame
You would need to have the hight of tire you plan to run & air it out, then measure from the floor to the frame & thats roughly how much you need to Z it
I would ad about an inch for wiggle room & a bump stop
As for the front I have a truck that was Z'd in the front, but I havent done it myself, so I am no help there
Here is a crappy pic of mine, its not done yet as I still need to plate it inside & out
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-01-2009, 12:17 AM   #3
FnLow69
FnLow69's Avatar
Re: Z'd frame?
some info here....
http://67-72chevytrucks.com/vboard/s...d.php?t=329498
FnLow69 is offline   Reply With Quote
Old 03-02-2009, 07:41 AM   #4
BFRO$TY
Re: Z'd frame?
Well we have a monster notch kit for the back that we know will put it all the way down but its just the front we need to lower more
Old 03-02-2009, 12:29 PM   #5
Str8Ugly
Re: Z'd frame?
http://dfwminis.net/forums/showthread.php?t=14311
check out there.. u might have to register but it shows how keef did his.. my z on my dually is 3" that is what is needed to get the front crossmember up high enough to lay
Str8Ugly is offline   Reply With Quote
Old 03-03-2009, 09:12 PM   #6
duceducenine
duceducenine's Avatar
Re: Z'd frame?
as the link above ^^^^shows........
can you really do a z'd frame with the motor in it?
thats seems amazing can the trans be hooked up too
as long as there is room?????
duceducenine is offline   Reply With Quote
