Old 03-01-2009, 08:29 PM   #1
hewlett2002000
hewlett2002000's Avatar
need help, cant find wiring diagrams..
if this should go somewhere else im sorry. im looking for colored wiring diagrams for a 2001 silverado 1500 with a 6.0l and 4l80e. im swapping the whole setup into my 66 and want to keep the whole harness from the 01 the way it is. i mainly need to know the wire colors for the passenger side front 02 sensor. also i need to know the colors of the tail light and head light/blinker wiring and where it exits the harness at. there are also a few other connectors cut off like the gauge cluster connector (i think thats what the wires are) and several other connectors that would go under the dash somewhere. since there are several wires there that are the same color i am going to have to trace those back to the ecm/bcm or wherever they come from to find out what they went to. something that would be very helpful is a plug identification chart if something like that exists. something that would identify plug color and type and list what they plugged to, and list the pinouts for each plug. i have ecm and bcm pinouts but have had no luck with colored diagrams. i used mitchell on demand from work to get the pinouts. i have heard alldata has better diagrams. is this true? any help anybody can provide is highly appreciated. if you need pictures i can take them tomorrow.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-01-2009, 11:21 PM   #2
hewlett2002000
Re: need help, cant find wiring diagrams..
here are some pics of the interior section of the harness, which is mainly what i need help with. heres a link to a photobucket album with pictures of it.
http://s226.photobucket.com/albums/d...chev66/Wiring/
and heres what i think they go to...
red = i think these go to the doors for the power windows/locks and such
yellow = i think the yellow one went to the air bag, and the big black connector went to the column for the ignition switch, wiper controls, blinker switch, and cruise control switch
blue = the PO cut these when he pulled the harness, i think they went to the gauge cluster/info center
pink = i have no idea what these two connectors went to. they were inside the firewall. any ideas on what they went to?
black = these go to the under hood fuse box as i unhooked them myself.....lol
green = these split off from the harness right before it enters the firewall. it looks like they headed towards the passenger side. maybe the blower motor? something to do with the ac? i dont know.
orange = i know this goes to something that is close to the headlight switch but im not sure what as i dont have access to another truck i can reference to.
Respect:
Old 03-04-2009, 01:08 PM   #3
drummin89
drummin89's Avatar
you still need, if so email me at rockfan1815@yahoo.com The diagrams can't be posted or sent over the board.
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 03-04-2009, 01:09 PM   #4
drummin89
drummin89's Avatar
did you also check autozone.com they have a database of repair procedures and wire diagrams.
Chris
Old 03-04-2009, 04:01 PM   #5
bpmcgee
bpmcgee's Avatar
I've got the full manual set for 2003, so I can probably get you the info you need. private me if you'd like me to check.
B
bpmcgee is offline   Reply With Quote
