how much $ into your dropmember
Just wondering what every one has into the dropmemeber with everything, including labor if you had it professionally installed. Just trying to find the average to compare against my z quote. Thanks in advance guys. Hopefully you guys don't mind talking $...
1981 - C-10 SCSB Planning on putting this thing on it's rocker! ![]() |
Re: how much $ into your dropmember
If you are just looking to go low, make sure you look at the other vendor options. They might save you some money.
I think the DM is the best way to go, but look at all your options. I just bought a C4 DM and I have $1800 in it already and I still have plenty more to go.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
67-72 parts collector,…
![]() Join Date: Nov 2002
tds,... make sure you are comparing "apples to apples" when you do this.
Figure all cost associated with the "Z". (like raising the engine, tranny, driveshaft tunnel, steering linkage, including sheetmetal work) Will the "Z" center the wheels in the wheel opening when you are done? Just some things to think about. I have a DM so I may be biased,... but I think that's the best way to go. The DM also improves the suspension geometry.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-22-2009 at 08:25 AM. |
#4 | |
#5 | |
The reason I'm plotting a z and a dropmember against each other is the fact I'm gonna have to z my front frame horns anyways when I body drop. So id do my body drop and z at the same time. My z quote was roughly 2k. Drop off, pick up. If a can dropmember for around the same or maybe 300 - 400 more then I will DM. But if its 1k more plus labor then I'm sorry ill sacrafice the looks and the benefits for the cash. This truck is for street beating anyways.
If you are paying to have it all done,... you probably won't get a DM installed for $2K or $3k.
![]() Join Date: Oct 2008
I have a DM and here is general checklists:
Dropmember: $1000 PorterBuilt 3'' spindles: $220 Godfather Customs Rack & Pinion $205 Summit Racing Steering Joints $? Hood Hinges $? Thats pretty much it, but if I left something out that is needed with the installation of DM, please add to list. Air bag system should not be included because your going to buy items regardless. I think you should consider a DM.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
#8 | |
I could either do it myself at my buddies shop or pay CTC. Depends on garage space and labor quote....
#9 | |
1981 - C-10 SCSB Planning on putting this thing on it's rocker! ![]() Last edited by tds; 03-22-2009 at 12:35 PM. |
#10 | |
cups arent going to be the same but you can mod them. get the dropmember soon, and with a group buy so it will just be around 1000 shipped. i think the price is going up the end of this month |
If its 1800 ill definatly go that route. How much is the price gonna go up? I need to call nate and ask him a billion questions.... like do I need a new power steering pump and all new lines? Do I need a new drive shaft? Must the tranny and motor be pulled?
search porterbuilts threads i think the one about 999 for the dropmember and it has a patrs list, and when the price will go up. i think this is it
http://67-72chevytrucks.com/vboard/s...9&postcount=33 |
#13 |
There 1200 plus shipping now..... maybe I can talk him back down
#14 |
If I could get it 1000 to my door id jump on it. Its gonna be like 1300 now....
#15 |
Prestige Worldwide
![]() Join Date: Feb 2001
I would say that with the quality you will find in a DM from Porter it will be worth the money! By the looks of them they should probably cost more based on craftsmanship alone..... (Don't read this Nathan
#16 |
TDS is the shop that quoted you 2 g's removing the motor and trans? Or just doing the Z, and nothing else?
To bad you did not live closer to me. I would Z your truck for ZERO.... |
#17 |
thats drop off and just pick up...
#18 |
Remember "Apples to Apples" so with your 2K Z will that also be all new steering parts? With the DM you provide a new Rack and Nate sends you the new outers so now your steering would be all new. Also the DM gives you better steering (by design) and better handling even with the standard kit. Also I don't think you will need a body drop with a DM. Spend a small amount more now and you will be much happier later.
Kevin LFD Inc. |
#19 | |
and even if the price is a little higher, so what? you are getting way more for about the same price. |
#20 |
VA72C10
![]() Join Date: Mar 2008
Noob question, but I am planning on a blazer and want to bag it. I am not planning on modifying the rear seats more than an inch or two so it will not lay in the rear....does it still make sense to do a dropmember? I would like to improve the geometry of the steering over just spindles and bags.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#21 | |
Kevin LFD Inc. |
#22 |
Actually the best bang for your buck would be to run a mustang II weld in cross member. You can purchase the M II crossmember fully loaded with drop spindles, M II steering and bags delivered to your door for under 2 g's. And you will have the wheels centered in the wheel opening as well.
The C-10 DM's are nice. Just cost to much for what you "don't get"...... |
#23 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-23-2009 at 04:03 PM. |
#24 |
Junior Member
#25 |
Here is one that comes to mind. But there are several kits that can be purchased for at or under 2 g's.
http://www.rjays.com/Heidts/hei-m2complete-pkg-01.htm The kit above is a little more than 2g's with out bags. I had the same kit on my 66 Impala that you can see in my build section. I was able to piece together my M II front end for the Impala with bags and 2" drop spindles for $1685.00. I am looking at the receipt right now..... So I can tell you from experience Mustang II front ends are the best bang for your buck. I will be doing the same M II on my 65 chevy truck. Here is the just the Mustang II cross member..... http://www.rjays.com/Heidts/hei-m2-xmembers-01.htm I have seen the Mustang II cross member as low as $250.00 on the net. I actually took measurements from my Mustang II cross member I had installed into my 66 Impala and will most likely build my own. There really is no "apple to apple" comparisons with a Mustang II front end. Mustang II front end components have endless upgrades possibilities. And you can use up to 13" disc brakes. If you want to get a truck low with great handling and front wheels centered in the wheel well. Mustang II is the best deal in my "hands on" opinion ... Last edited by six5; 03-23-2009 at 06:45 PM. |
