BBC oil pan leak
I am replacing the oil pan gasket on my GEN IV 454. It has a 4 piece gasket and I was wondering what is the best parts and method to install.
I am told felpro has a one piece rubber gasket. Has anyone here ever tried one? Are they any good? |
Moderator
![]() Join Date: May 2007
Re: BBC oil pan leak
Use a one piece gasket, problem solved
Do you recommend any RTV with the one piece?
![]() Join Date: Sep 2005
no rtv needed. i've used 4 piece gaskets with no problems jsut put a little rtv when the 4 corners f the gaskets meet
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
i used a one piece and put a little rtv in the corners no leaks after 30 plus k
Active Member
I have used the mr gasket and the felpro one pc - no issues with either - I like the light gray color of the mr gasket better - I still use a small amount of RTV on the corners as insurance
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Thanks guys.
