03-27-2009, 09:08 AM | #1 |
14 bolt rear
will a 14 bolt be too wide in a 69 k10?
03-27-2009, 09:16 AM | #2 |
Re: 14 bolt rear
welcome to the board.. a lot of guys have done that swap.. i'm a 1/2 ton guy though...
As long as your leaf perches are the same then it should bolt right in, or you can weld new one's. I actually put a 12bolt from a 2WD into my K-10 which was a little wider, it looks better with matching axle widths anyways (K-10's always had a slightly narrower rear than front axle) PM grendel, vtblazer or Mudder for specifics on that swap
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-27-2009, 09:50 AM | #3 |
Post Whore
Re: 14 bolt rear
What is the 14 bolt out of. 3/4 ton or 1 ton.
I put a 14 bolt full floater from a 1978 3/4 ton in my K5. Had to move the spring pads and change the shock mount location. Also need to get a conversion u-joint.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-27-2009, 09:54 AM | #4 |
Re: 14 bolt rear
No need to PM, the info's all out here in the threads... Search and ye will find.
a single rear wheel, 1 ton 14B is a bolt in for our leaf sprung (rear) trucks. Last edited by FormerMember; 04-02-2009 at 02:52 PM. |
03-27-2009, 09:56 AM | #5 |
Re: 14 bolt rear
Conversion ujoint to use your existing driveshaft:
NAPA part number 348 Dana Spicer part number is 5-460X 1310 - 1350 Last edited by FormerMember; 04-02-2009 at 02:53 PM. |
03-27-2009, 07:50 PM | #6 |
Re: 14 bolt rear
thanks guys. the axle is out of a 3/4 ton but i never even gave a thought of the u-joint.
03-27-2009, 07:53 PM | #7 |
Re: 14 bolt rear
You will need to move the spring pads in about 2" each side then.
