Old 03-28-2009, 10:36 AM   #1
blazer2007
trying to find info on manual valve
I was trying to find info on manual valves,does the toggle let air in the bag and also out or do you need 2 toggles per bag.I thought would be a easy setup for a overload type bag setup in the rear
blazer2007 is offline   Reply With Quote
Old 03-28-2009, 11:12 AM   #2
fixit-p
fixit-p's Avatar
Re: trying to find info on manual valve
It depends on what valve your using three way valves exhaust through the valve itself or you could install a quick exhaust valve near the air bag that way you dont have all the air exhausting in the cab other than pilot air or you could use a three way solenoid valve(http://www.macvalves.com/products/3way.htm) and just install an electric toggle reduces plumbing and no pilot air
fixit-p is offline   Reply With Quote
Old 03-30-2009, 12:50 PM   #3
duceducenine
duceducenine's Avatar
http://www.streetbeatcustoms.com/Che...rols-Switches/
these are what i used on my 72 c10
1 switch up and down they are your valves!!! paddle style switches
duceducenine is offline   Reply With Quote
