Old 03-29-2009, 01:53 PM   #1
sams60gmc
sams60gmc's Avatar
Yukon knocking noise?
Hey guys I'm new to this section of the forum, I'm usually hiding out in the 60-66 board. But anyways I've been having this problem with my truck (04 Yukon), when it gets close to my oil change like within 500 miles it starts making some loud ticking/banging noises from the top end of the motor, kinda sounds like a diesel, it only happens when the motor is completely cold and happens for about 5 minutes til the motor starts to warm up. My Dad and I think its a stuck lifter or something up in the valves, any ideas? What about adding some sort of additive to my oil? The truck only has about 70000 miles on it and runs perfect after the knocking dies down. Thanks for the help.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 03-29-2009, 09:04 PM   #2
truckdude239
truckdude239's Avatar
Re: Yukon knocking noise?
what kind of oil filter are ypou running? sounds liek ti is runnign low on oil. that motor holds 6 qt of oil. as to filter stay away from fram. run a purator or ac delco filter, or even wix all of these are good filters. i would put a bottle of mystery oil in it and go from there
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-31-2009, 11:08 AM   #3
Josh
He's got mean nasty FANGS!
Josh's Avatar
Sure it's not piston slap? What kind of oil are you running in it? These motors have very short pistons with low tension rings which allows for some piston slap when cold. How often are you changing the oil? Is it using any?
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 04-07-2009, 06:55 PM   #4
billnorman
You might try Seafoam before your oil change. I had similar noise in other-half's car. Half a can of Seafoam; no more noises.
billnorman is offline   Reply With Quote
Old 04-11-2009, 08:30 PM   #5
gmclowsierra
im going to say its the piston slap. my 2000 yukon with the 5.3 does the same thing. no fix at this time according to gm
gmclowsierra is offline   Reply With Quote
Old 04-13-2009, 12:00 PM   #6
sams60gmc
sams60gmc's Avatar
Yeah Ive heard about the piston slap back when I had my 02 Silverado, It could be that, not sure. Did an oil change and noise went away.. for now anyways. I'll take it in for waranty if it starts doing it again soon.
Old 04-13-2009, 02:08 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
"Piston Slap" was supposedly eliminated by 2003. It shouldn't last more than 30 secs to a minute or so. 5 minutes is a long time. Mobil One really seems to quiet mine down in the winter and it's not audible in the summer in the warmer temps.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-13-2009, 05:23 PM   #8
cmart
cmart's Avatar
My 99 does it. My uncle bought a 99 new and an 03 new and they both have done it. The dealer kept telling him that it's normal and not to worry about it. He spoke with someone the other day and they were very aware of it and they told him to put a quart of transmission fluid in it when changing the oil. He did and so far it hasn't done it.
I'm kind of skeptical of the tranny fluid, but he's tickled to death with it so far.
1999 Chevrolet Silverado 1500 extended cab, short bed. 5.3L automatic.
cmart is offline   Reply With Quote
Old 06-02-2009, 03:55 AM   #9
sams60gmc
sams60gmc's Avatar
We'll I guess I'm back here talking about my ticking noise again . So here it is. Everything was going fine since the last oil change then I drove it to the coast aprox 2 hours away. Came back and it was doing it really bad. Talked to the service manager at the place I bought it from and he said he would take a look at it. He thinks its a stuck lifer. They put a quart of Rislone in it. He said its an additive to help stuck lifters. It helped til I drove it to Medford aprox 30 minutes away. Now its doing it again and did it tonight the worst it ever has. So I'm taking it back in this week to see what they can do. Thats pretty interesting about the transmission fluid. What does he use, like 5 quarts reg oil and 1 quart trans? I will ask them if there would be any downfalls to using it. I wouldn't see why. It seems like my truck likes to start after long trips.
Old 06-02-2009, 09:14 AM   #10
cmart
cmart's Avatar
Yes, he puts one pint of tranny fluid each time he changes the oil. This guy that was telling him this is a GM mechanic and he said that three or four oil changes is all it will take and that it will probably stop all together. He's on his second oil change now and it's not ticking anymore. I will probably try it with mine the next time mine is due for an oil change.
Please keep us posted to what they tell you. Thank you for the update.
Cory
Old 06-02-2009, 02:00 PM   #11
sams60gmc
sams60gmc's Avatar
I'm deffinatly going to try it. Anything that wont cost alot and hopefully will fix my problem I'm all for it. How loud are your guy's noises that you have? Also when you drive it does it feel guttless, because mine does til the noise goes away.
Old 06-02-2009, 03:37 PM   #12
cmart
cmart's Avatar
Mine just does it when the truck is first started cold. It will tick for about fifteen to twenty seconds or so and it quits. It does it longer in the cold months of the winter, but i'd say for only a minute or so and it quits.
Cory
Old 06-02-2009, 04:11 PM   #13
sams60gmc
sams60gmc's Avatar
Mine is pretty loud and lasts for quite a while. Kinda sounds like someone sticking a stick into the fan maybe??
Old 06-03-2009, 03:10 PM   #14
sams60gmc
sams60gmc's Avatar
So I took my Yukon to the shop last night, they started it this morning and determined it was a stuck lifter. They said it would cost 2200 dollars just to fix it. I can't go that route. I think I'm going to try the ATF in my oil and change my oil this week because that always helps. My only concern is what problems could this pose in terms of hurting anything internally if I ignor the problem or is it just going to be an annoying noise. Also why did this happen in the first place.
Old 06-03-2009, 08:07 PM   #15
Josh
Josh's Avatar
Get some GM E.O.S. assembly lube and dump it in. I've done it on several 3.4 v6 vans to get em to quit making noise. I'd try some additives first, but be warned they can damage other stuff if used incorrectly. You can buy a used 5.3 or less than $2200... It'd probably cost less to put a used engine in it than the cost of pulling the heads to replace a lifter. Last 5.3 I had with a cracked head it was cheaper to put a lower mile than the truck used 5.3 than it was to buy a new head/gaskets/added labor....
Josh
2004 K2500 Burb
1999 C3500
1969 C-10
1967 C-10 Panel
Old 06-04-2009, 03:07 AM   #16
sams60gmc
sams60gmc's Avatar
I think I might seafoam the motor before my oil change. Couldn't hurt it.
