Old 03-30-2009, 12:23 AM   #1
phantom4
Caliper Leaking
I am wondering if anyone else is having a problem with replacement 4wd calipers.
I have tried 3 calipers now from NAPA and they all have a small leak between the banjo washer and the caliper, they will leak with no pressure other then head pressure from gravity.
I am currently using Inline Tube extended brake lines and the hardware that came with the calipers. I have tried stacking some banjo washers to see if I can pick up the imperfection in the caliper surface but I still have a slow leak.
Any recommendations on where to find some decent calipers?
phantom4 is offline   Reply With Quote
Old 03-30-2009, 06:55 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Caliper Leaking
Maybe a little of this on the threads. Just don't put in on the first thread or two so it cant get inside your system.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-30-2009, 03:38 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Caliper Leaking
moved to the 4X4 section, you may get better feedback over here.
Old 03-30-2009, 06:24 PM   #4
Fubar
Fubar's Avatar
Re: Caliper Leaking
Uh-oh, I just bought some from napa. But I haven't put them on yet, so I'll have to wait and see.
Fubar is offline   Reply With Quote
Old 03-30-2009, 08:53 PM   #5
phantom4
Re: Caliper Leaking
The threads are not the problem.
The washer seating surface on the caliper is the cause.
Sport/Truck if you don't mind let me know the outcome of your calipers, maybe my local store had a bad batch of them.
