Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-01-2009, 07:05 PM   #1
72 SUPER10
Cool Almost ready for launch 10.5 mean street
Pics coming soon , transforming my clone 2 year old resto red/white cheyenne super into a 10.5 m/s or some call quick street, just finished the rearend, 33 spline strange axles,5/8 s studs,prorace full spool, strange rear brakes,shock relocaters ,adjustable panhard bar,ultimate alum cover,c-notch frame strange shocks,5 inch ccp springs,with pinion shims,29.5/10.5 on weld aluma stars 10 wide,..... Front work done also with strange front rotors and brakes,trick front springs and shocks, removed front sway bars and lower a arm snuper towers, installed limiters, front wheels are weld aluma star 2.0 s wide spokes , small block is ready to come out for the big block 468 to install the motor plate,i will be putting the chrome moly 12 point cage when the motor is trial fitted, posting pics soon , thanks for reading. Vince.
72 SUPER10 is offline   Reply With Quote
Old 04-01-2009, 07:43 PM   #2
Wild83C10
Wild83C10's Avatar
Re: Almost ready for launch 10.5 mean street
Sounds like fun. Good luck with it.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 04-01-2009, 08:28 PM   #3
Super73
Super73's Avatar
Sounds pretty cool there Vince.. What are you hoping to run ET wise?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-02-2009, 12:10 AM   #4
72 SUPER10
Its a 6.50 index 1/8th
Old 04-02-2009, 02:45 PM   #5
nxtruck
nxtruck's Avatar
Looks like a cool build! Do you plan on street-driving it any? And concerning the class you plan on running, is it a n/a class or are power adders allowed?
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 04-02-2009, 09:47 PM   #6
72 SUPER10
yes power adders are allowed, yes im driving it on the street some, the rules are like real street in away, you must run 10 wide wheels max, and any size rear drag radial with a section witdth of no more than 13.0 and must be tucked under and not sticking out past the body, as for slicks 10.5 max is only allowed no Ws.and stock style susp, and must retain stock frame rails and must retain tag, insurance, and be stock looking body, ill see if i can find a set of the rules. i have seen dj racer at some of the real street races from time to time when i go with my buddy with his car. my goal is to run real street but for now im trying for quick street. and the trucks are just way cooler any way. im taking some pics now and will try my luck at posting them i think yall will be proud, thanks vince
Old 04-02-2009, 10:04 PM   #7
69trk
69trk's Avatar
can't wait to see the pictures.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-03-2009, 12:02 AM   #8
nxtruck
nxtruck's Avatar
Sounds like a fun class to run in! I'm curious to see the pics, as well. Judging from the list of parts above, you've spent a good deal of time and money on it. And you're right; trucks running in heads-up type stuff like this are WAAYYY cooler than cars!
What track is it that is running these classes?
Chris
Old 04-04-2009, 01:44 PM   #9
72 SUPER10
Old 04-04-2009, 01:53 PM   #10
72 SUPER10
Originally Posted by 72 SUPER10 View Post
trying to down load pics all day
Old 04-04-2009, 04:50 PM   #11
72 SUPER10
