04-21-2009, 10:01 AM | #1 |
Stupid Question about burnouts
i have a 3 speed manual rear wheel drive. it has disks in the front and drums in the back. will revving it up, dumping the clutch, and holding down the break damage the rear brake? i have enough power to do it, but i am worried about damaging the rear brake drums.
1972 longbed- 454 1967 shortbed- 355 |
04-21-2009, 10:12 AM | #2 |
Re: Stupid Question about burnouts
Yeah,why wouldn`t it?Are the brakes all you`re concerned about?
04-21-2009, 10:15 AM | #3 |
Senior Moment
Think about it. You’re trying to stop your wheels by holding down the brake but they continue to spin because you’re pouring the coals to it. You'll be replacing brake shoes more often at the least not to mention the strain you’re putting on the rest of the brake parts.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
04-21-2009, 10:16 AM | #4 |
thats what i thought
04-21-2009, 10:20 AM | #5 |
dazed and confused
you could buy a line loc to lock the front brakes and it will do better burnouts
members met: redbaron69, billsbowtie,nc67 |
04-21-2009, 10:26 AM | #6 |
i read about that, how much are they?
04-21-2009, 10:35 AM | #7 |
Why not buy a P.O.S. truck to tear up, and keep your nicer one for driving like you care about it? or you could just pull it up to a brick wall if you like spinning a tire, it is easier on the brakes?
04-21-2009, 10:35 AM | #8 |
'69 Chevy SWB
Or one way to solve the stress on the rear brakes and still enjoy the good times would be a roll control kit(AKA line lock). Plus that would eliminate the hard dump on the clutch to. Since you would only have to control 2 pedals instead of 3. You can just easy it out till it starts to engage, and ta da. SMOKE (hopefully from the tires and not the clutch) Jegs sell a complete kit that's easy to install and use. A friend of mine has this kit on his 600hp LS1 camaro and It hold it very nicely.
http://www.jegs.com/p/JEGS/805233/10002/-1 |
04-21-2009, 10:36 AM | #9 |
'69 Chevy SWB
04-21-2009, 10:58 AM | #10 |
My God, I have tuned into my father.....I think I see a nose hair...LOL
04-21-2009, 11:41 AM | #11 |
AMERICAN IRON ADDICT
The other thing to consider is the rear end. If it's a open rear, your just spinning the right rear and gear oil isn't traveling to the axle bearings or side gears. After a period of time damage can occur. A posi is better as both axles are spinning and the carrier is operating the same as driving down the road. I would second the line loc idea and keep the other info in the back of your mind. Breaking stuff is just part of the fun!!
04-21-2009, 12:23 PM | #12 |
I built it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
04-21-2009, 01:00 PM | #13 | |
Heck,why not mount a couple bleach jugs upside down in the bed in front of the tires (tire?) with a release cable so you can make a puddle to smoke out bigtime?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-21-2009 at 01:01 PM. |
04-21-2009, 02:01 PM | #14 |
I had a 94 Chevy with a 5 spd and a 6cylender 4wd in high school. I used to do that drop the clutch and hit the brakes move all the time...........Until the last time! I dropped the clutch and BANG! it didnt go anywhere, and of course it was in front of the school with everybody watching!!!!!! after the BANG i let the clutch out in gear and got out and looked under my truck and the drive shaft was turning but nobody was home!!! so I put it in 4 whl drive and drove home on the front end until the axles started to slide out and my truck looked like a roller skate!!!
But I had fun doing it..... also learned how to rebuild a rear end........ |
04-21-2009, 02:38 PM | #15 |
i did that in the snow in my eclipse and burnt my clutch so i wouldnt try it
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-21-2009, 04:04 PM | #16 |
its all about the +6 inches
this isn't as detrimental as everyone makes it sound. It is no worse for the brakes than in an automatic doing a burn out.
You'll do more damage to your tires than anything else. Your described method is all wrong though. Left foot on clutch to the floor. Right heal on brake, toe on throttle. Bring the rpms up to about 1500 - 2000, and bring the clutch pedal up. Don't just pop the clutch, that's when parts fly, but bring it up fairly quick. Then move your left foot to the brake while staying in the throttle. You don't want to mash the brake pedal, you just want to keep enough pressure to keep the truck in place. Same on the throttle, you don't want to floor it, just keep the RPMs up around 2500 - 3500 once the tires start spinning. This is all pointless unless you are warming up slicks at the starting line. If on street tires, you aren't helping much at all. just a quick 10 foot burn out is all you need to knock the gravel out of the tread. (go around the bleach box if on street tires) You will be AMAZED at how quick you'll kill street tires. Seems no one knows how to do this anymore. When I was in highschool, you weren't considered a car guy untill you could manage this... even in a 4 cylinder S-10, doing this in a stick shift made you OK in car circles. Last edited by Longhorn Man; 04-21-2009 at 04:06 PM. |
04-21-2009, 07:36 PM | #17 |
longhornman beat me to it.
..what he said, plus dumping the clutch then slamming on the brakes is not only hard on stuff, but it also looks really stupid ive done a fair number of brake stands in my truck, and the drums dont seem to be wearing too fast, the whole thing that kills brakes is heat, if you dont stand for too long, the brakes wont get too hot, thus saving your brakes (for what its worth). also, letting the truck just roll forward slowly, helps to keep a very minimal amount of rear brake pressure on, saving brakes, and its easier on your tires.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. Last edited by 69halfton; 04-21-2009 at 07:36 PM. |
04-21-2009, 08:19 PM | #18 |
Grandpa in the rustmobile...
i just did this today...lol
how longhorn man said it..made some nice black marks in front of the house and gf telling me to stop and hoped id get a ticket lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-21-2009, 08:28 PM | #19 |
it takes a few times to get it right, but once you do, you'll amaze your friends.
I did it a few weeks ago for the first time in 15 years or so.... and it all came back to me instantly. |
04-21-2009, 08:43 PM | #20 | |
Redefining LowBudget
ummm don't you mean add a winshield washer ( with pump) and a squirter to each wheel ............no man in his right mind would ever do something like that...Roflmao..
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-21-2009, 08:52 PM | #21 |
Itdefinately puts alot of stress on everything from the clutch on through the drivetrain.The brakes would be the least of my concern.They won`t break,just wear faster.That`s why I asked if he was only concerned about his brakes.To me it`s awfully lame to have to put that much effort into doing a burnout,especially in a light in the rear pickup.If you ain`t got the juice you got nothing to show off.It`s like cutting real hard pulling out,finding a patch of loose stones,or a wet spot to make a one legger spin.I`m always impressed,but not in a positive way.It`s called tryin`too hard,IMO.What`s cool is a ride turning both tires effortlessly.
I don`t think it`s the stray hairs on my nose.I elt the same when I was young. But,as always,that`s me and if that`s what rocks your boat...
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-21-2009 at 08:54 PM. |
04-21-2009, 08:52 PM | #22 |
I built it
THAT WOULD BE AWOSOME!!!!!!!! why havent i thought of this???
04-21-2009, 08:56 PM | #23 |
not only would it be hard on your brakes but also on the clutch. if your worried about brakes then just do donuts. thats what i did until i figured how to tune an engine properly. now i can even spin both tires with an open diff
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
04-21-2009, 09:06 PM | #24 |
Eat My Rust
Honestly, once you brake the tire(s) loose, there is less load on the drive train then there is when your accelerating.
When the tires loose traction, there is a ton less friction between the road and tire, hense why skidding and spinning tires is not the fastest way to stop and start. Once you initiate the burn out, you have less load on the drivetrain than you would accelerating with full traction. Also why car's tend to break parts on a launch, not the burn out. This is why you can hit third gear at say, 25mph instead of 70mph, or what have you. With the lack of traction, thus less resistance to the drivetrain, everything can spin faster, easier, and thus, burn rubber. The most stressful part is breaking traction, but if you get good, this takes nothing. The Fastest thing to wear is tires. The next is brakes. Watch your RPMs and don't get too excited, letting them climb too high. And I loved the posi burnouts my truck used to pull when I 1st started driving it. Nothing like holding a 4500 lbs truck at a 20 degree angle for 100 feet.... Sadly I can't ever get it to do a posi one much That, and don't care to tear up the new tires much. Last edited by texanidiot25; 04-21-2009 at 09:09 PM. |
04-21-2009, 09:21 PM | #25 | |
