Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-26-2002, 04:50 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Dropped...now wheel interference!
We just dropped our '77 C10 with DJM 3-inch spindles and 2 inch springs in front. The old Krager 15 inch wheels have some slight (bout 1/16 inch) interference with the spindles. Will 16 inch wheels fit or will I have to go with 17's? Anyone have to deal with this problem?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-26-2002, 04:57 PM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
Are they scraping on the A arms? I heard that you have to grind off some of the A-arm lip to eliminate the scraping on 15" wheels. This however is not the case if you have 16" or 17" wheels.
78SilveradoSWB is offline   Reply With Quote
Old 12-26-2002, 06:10 PM   #3
stllookn
stllookn's Avatar
The portion of the casting that holds the disk brake calipers is scraping on the inside of the wheel. I have not turned it side to side to the locks to see if it interferes with the "A" arms yet. One thing at a time...LOL! It is just the top outer portion of the casting too.
Old 12-26-2002, 06:30 PM   #4
78SilveradoSWB
Post
I think also mentioned in previous posts about this is grinding off some of the spindle surface which I think may be in DJM's instruction sheet that came with the drop spindles. You might call DJM's customer service.
Old 12-26-2002, 06:45 PM   #5
stllookn
stllookn's Avatar
I tried DJM and they are closed today...LOL! It looks like I can grind off that section of casting...I only need about 1/16" and it is not a highly stressed section anyway. I was just hoping someone had done this. I will check their on-line installation instructions. There were none in the box! Thanks for reminding me about that.
Old 01-10-2003, 11:22 PM   #6
newage
16s will work but prefer 17s for better clearance and apearanc
newage is offline   Reply With Quote
