Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-27-2009, 05:40 PM   #1
Prerunner1982
Prerunner1982's Avatar
Lumbar switch
On my wifes 97 s10 Blazer, the lumbar support switch shorted out. I have known this for awhile and have all the power to the seat disconnected.
GM did not think about the placement of the switch very well seeing as how when you slide in and out of the seat you put your weight on the edge of the seat. With the switch in the side of the seat rather than mounded lower on the frame it finally broke the wires and was shorting on the inner seat frame causing the internior lights to come on..
My question... How do you remove the switch. I would like to fix the wiring as we are contemplating selling/trading it in.
Thank you.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-27-2009, 10:02 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Lumbar switch
At's a good question. I'll have to look at my lumbar switch tomorrow....truck is at a body shop for some "surgery" to correct the effects of trying to occupy the same space at the same time with another solid object.
You might try using a telescoping mirror to see if you can look up under the seat and see where it lies. Or, if you can find one at a dealership, maybe looking at the new switch will give you a clue as to how it mounts.
Member Nr. 2770
Old 05-01-2009, 09:01 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: Lumbar switch
I would look at my spare seats but I gave them to Corn a year ago. maybe he can check.
68C15 is offline   Reply With Quote
