05-02-2009, 03:37 PM | #1 |
35 inch tires
i have a 1972 chevy blazer and i want to put 35 inch tires on it. can i put a 4 inch lift on it or a 6 inch lift and if i go with the 6 inch lift is there any othe modifacations i have to do to it.
thanks |
05-02-2009, 04:47 PM | #2 |
Re: 35 inch tires
Hey 72, not that I'm a veteran member, but welcome to the board! You can squeeze a set of 35's under a 4" lift but there is an area on the front of the front wheel well known as the "fang" where your tires may rub depending on the backspacing of your wheels. Also take the width of your tires into account, anything wider than a 12.50 probably won't fit without excessive rubbing or fender trimming... Also, with a 6" inch lift, it is generally recommended that you get some form of steering correction like a raised steering arm or drop pitman arm and you may want to invest in some extended brake lines as well. If you plan to do any moderate to hard wheeling, I would say go with the 6" so that you have more room for articulation but if you are just goong to use it on the street the a 4" should be fine. Hope this helps, see my profile pic for a 4" w/ 35's.
05-02-2009, 09:13 PM | #3 |
Re: 35 inch tires
I have a set of 35x12.50s on mine using factory rally wheels with no problems.
05-02-2009, 09:15 PM | #4 |
Re: 35 inch tires
forgot to mention im running a 4 inch lift
05-03-2009, 06:29 PM | #5 |
Re: 35 inch tires
if i go with the 6 inch is there any modifacations that i have to do to the drive shaft or transfer case.
05-03-2009, 06:46 PM | #6 |
Re: 35 inch tires
If you go with a 6" you most likely will have to lengthen driveshafts.
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
05-03-2009, 08:10 PM | #7 |
Re: 35 inch tires
The rule of thumb here is you can run 35s with a 4" lift if you're mostly street or light wheeling. If you're gonna do any more than that, go with a 6" lift or you'll tear up the sheetmetal.
A 6" lift is about the most you can get out of the stock shafts. Any more than that and you should plan on new ones. |
05-03-2009, 11:03 PM | #8 |
Re: 35 inch tires
thanks for the help guys.
05-04-2009, 07:11 PM | #9 |
Re: 35 inch tires
I would highly recommend going with a CV joint at the transfer case in the rear if you are goind to lift it 4 or 6 inches. Otherwise, you will get a driveline vibration from excessive driveline angles. You will also go through driveshaft joints like nobody's business. I have a 6-inch lift and had to go with the CV joint in the rear in addition to longer shocks, brake lines, and drop drag link.
05-05-2009, 07:05 AM | #10 | |
Re: 35 inch tires
The answers are contingent on how you want to drive it and where you want to take it. Along with what the others have said, adding a 6" lift starts to throw you into the world of cross over steering being a good idea too. Gearing also comes into play, 4:10's would be great but if your currently running 3:08's, it's a poor combo. |
05-05-2009, 10:55 AM | #11 |
SKINNY TIRES RULE!
Re: 35 inch tires
Wheel off-set will play a big part in your clearance too. Adding Zero Rates will help re-center the rear wheels in the wheel openings and help level the truck too.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
