Old 05-04-2009, 11:19 AM   #1
19684x4k20
1968 k20 needs help with steering correction
i lifted my 1968 k20 6" closed knuckle front axel manual steering . dont get full right turn ."any advice have pics not sure how to post here
19684x4k20 is offline   Reply With Quote
Old 05-04-2009, 01:33 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 1968 k20 needs help with steering correction
Adjustable drop drag link is what you need.
Here is a pic of the one on my 69 K20
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-04-2009, 02:47 PM   #3
slednD1
slednD1's Avatar
you may have the pitman arm clocked wrong...easy check...set steering to straight ahead,remove pitman arm from box,now turn either way to stop and count turns while turnig back,should be about 3 1/2 to 4 turns.now find center of travel in steering box and re-install pitman arm/the pitman arm can be installed in four different positions so find the one that is closest to straight.and as JACK said you should have a drop drag link like the one in the picture good luck
slednD1 is offline   Reply With Quote
