Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-04-2009, 04:03 PM   #1
Rafael505
Rafael505's Avatar
94 s10 4 cyl 2.2 why gas in oil
Well, I'll start with the fuel injectors, 2 were leaking I replaced them, now when I cranked the truck, gas was flowing out the exhaust, ok well fine ,, haha,, Now? it cranks for 2 seconds and the motor locks, It sounded like its coming from the starter and fly wheel, so I checked them, starter is good , fly wheel looked good but not sure I'd have to pull the tranny out to really get a good look,, I thought I would check the oil well theres gas in the oil,, I drained it and put new oil but still cranks about 2 seconds then it locks ones again,, I can manually turn the motor but not with the key,,,? anyone have an ideal why this is??? Thanks for the help.
Check out my Photos
http://67-72chevytrucks.com/gallery/...ry.php?cat=769
L.L. N.M.
63 chevy c-10
67 chevy c-10
71 chevy Blazer 4x4
Rafael505 is offline   Reply With Quote
Old 05-04-2009, 07:12 PM   #2
BarryB
BarryB's Avatar
Re: 94 s10 4 cyl 2.2 why gas in oil
If you starter is good, I would then check to see if it is dropping power after, the 2 seconds of cranking. Might have a bad starter solenoid, bad igniton switch, neutral safety switch, number of things.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-05-2009, 03:39 PM   #3
Myself
Been there, done that. Your new injectors are not fully seated. This allows fuel to fill the cylinders. You have inadvertently left pieces of the old injector o'rings in the holes. It has to come back apart. Pull all your plugs and put a plastic bag, or old towels, over the plug holes. Then put some 2x4's or something on top of that. When you crank the engine over LOTS of fuel will come shooting out. NO SMOKING!! I too have worked on Satan's S10!
Myself is offline   Reply With Quote
Old 05-06-2009, 03:53 PM   #4
Damien
Damien's Avatar
Make sure you disable your ignition or ground the plug wires far away from the spark plug holes.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
