Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-13-2009, 02:44 PM   #1
Imacarguytoo
350 Performance Question
Im putting together a 350 and curious how its going to run and idle. Will it at all have a somewhat racy idle?
350 stock bottom end
flattop pistons
76 CC 1.94 1971 corvette LT1 heads (stock)
edelbrock performer rpm intake
holley 600 mechanical sec.
center dump manifolds with duals
Speed Pro Cam
# cs-1095R Hydraulic Cam
Specs on cam
.050 dur in. 224 EX 224
sae duration intake 291 EX 287
cam lift In. .300 EX. .307
valve lift In. .450 EX. .460
lobe centers IN 114 EX 114
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 05-13-2009, 04:52 PM   #2
Irishpilot
Re: 350 Performance Question
With that cam, I'm guessing it is going to be a mellow idle with the 350. Is that a thumper cam? If so, I'm not sure how the idle is on those.
What is the rpm range that cam is speced for? For trucks, I usually try to get a cam that produces power in the lower rpm range. I think my cam is speced for 1500-5500 rpm range.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 05-13-2009, 06:36 PM   #3
Imacarguytoo
No its not a thumper cam. The info i found for it is.....
350cid/ 350 HP LT-1, L82 Hydraulic camshaft
2200-5500 RPM Range.
This cam is for my jeep which weighs 2600 pounds with me in it.
Old 05-13-2009, 10:56 PM   #4
Jim_PA
I'd go with a standard Performer or Performer EPS intake. Should make better low-end power and throttle response. I doubt you'll be turning much over 5500 with it anyway.
Jim_PA is offline   Reply With Quote
Old 05-14-2009, 07:00 AM   #5
Imacarguytoo
Thanks but i gotta stay with the combo i have. Im doing this project for my jeep which is gotta be as cheap as i can go. lol Gotta keep the real money for the C10. Im just curious how the power will be in it and the idle quality.
