Old 05-13-2009, 07:08 PM   #1
jglz67
Question modifying 4.8 vortec wire harness need help.......
Dropping the motor in my 67 already, got told I need to modify thee wire harness but clueless on wat to do anyone have a diagram or can tell me exactly wat to do...
jglz67 is offline   Reply With Quote
Old 05-13-2009, 08:37 PM   #2
BADSAM
J'ville Junkman
BADSAM's Avatar
Re: modifying 4.8 vortec wire harness need help.......
Go check out LS1tech website, I understand you can get everything you need there. There is also a good writeup in the FAQ that mentions the wiring stuff. It might be called a 5.3 swap on the cheap or something.
Goodluck.
72 3/4t Suburban 402BB (Daily driver for 8 years)
68 GTO (never ending proj)
91 Kawasaki ZX-7R
57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans)
73 Corvette (17 yr old daughter's: Another project - what's wrong with me?)
53 Willys M38
BADSAM is offline   Reply With Quote
Old 05-13-2009, 09:08 PM   #3
kamikazekyle05
kamikazekyle05's Avatar
I went to lt1swap.com and got the pinouts for my harness, ive printed them out and went down each pin to see if i needed it or not
kamikazekyle05 is offline   Reply With Quote
Old 05-14-2009, 12:59 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
wait 4 me performance will hack up your harness and tune with free unlimited retunes for $360. i sent mine off yesterday. they eliminate the vats, not just some added box like most.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-14-2009, 02:05 PM   #5
jglz67
cool thanks hopefully i get it done pretty quick i want the truck running already... what do yall plan on doing about the gauges, can we use the new a/c system?
Old 05-14-2009, 09:22 PM   #6
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
Here you go
http://www.ls1tech.com/forums/conver...shortstep.html
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
72 SHORTBED 7.0 is offline   Reply With Quote
Old 05-14-2009, 09:49 PM   #7
brad_man_72
the boat guy
gauges, you have to have the comp reprogrammed to sent out a v-8 tach signal, you can drill and tap plate above oil filter to make oil gauge work, rt head near the rear their is a plug you can remove redrill and tap for temp sending unit.
if using a transmission that doesnt have a speedo cable you need an eletronic speedometer (definatly cheapest and easiest fix, but not the only way to do this)
im putting an eletronic speedo behind my factory gauge face and needle. im thinking a 94ish s-10 speedo will "work"
Old 05-14-2009, 10:16 PM   #8
kamikazekyle05
Id like to see and hear more about this
Old 05-14-2009, 11:17 PM   #9
68 short step
gauges, you have to have the comp reprogrammed to sent out a v-8 tach signal,"
also most aftermarket tachs have a switch/s to make the tach read 4/6/8 cyl. you can simply put the tach into 4cyl. mode and it'll read accurate, w/out changeing the tach output of the PCM.
68 short step is offline   Reply With Quote
Old 05-15-2009, 01:48 PM   #10
brad_man_72
the boat guy
ill be sure to take lots of pics, and if i get it to work ill post up a how to. i think i heard about somebody else on the board doing something simmilar.
Old 05-16-2009, 12:15 AM   #11
boostat4500
Another option for the oil pressure gauge is to just use the stock hole behind the manifold. The PCM doesn't need the stock sending unit signal. Adapter bungs are also available for the temp sensor if you don't want to drill and tap.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 07-27-2010, 08:32 PM   #12
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
You have to make an adapter though the LS oil sender seals with a gasket and straight metric thread the "truck" sender will be pipe.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 07-27-2010, 09:40 PM   #13
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Although it's an older thread, I'm gonna move it to the LS swap area.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
