05-16-2009, 11:34 AM | #1 |
Grandpa in the rustmobile...
alternator wiring ?, where should i run this wire i dont understand the diagram..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-16-2009, 11:36 AM | #2 |
Re: alternator wiring ?, where should i run this wire i dont understand the diagram..
wait, does it mean i run it to a keyed power source on the fusebox?
key on, alterator on key off, alterator off correct me if im wrong please
05-16-2009, 12:30 PM | #3 |
Here's a easy wiring conversion....... http://67-72chevytrucks.com/vboard/s...d.php?t=119379
1997 GMC Sierra Ext 1965 Mustang |
05-16-2009, 12:53 PM | #4 |
You are correct #2 goes to a switched battery source.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-16-2009, 01:32 PM | #5 | |
Msgt USAF Ret
If it is the 3 gauge dash then the brown wire that went to the old external voltage regulator simply plugs in at #2. There was a blue wire there from the external regulator but it is just an extension of the brown wire. Refer to the thread posted by 70GMCer. If you have a seven gauge dash with ammeter then you can run a wire from any switched 12 volt source, BUT, you will have to wire a resister in series with that wire before you connect it to the alternator OR you may blow the diodes in the alternator and it will not charge. A 75 ohm 3 watt resister will do the trick. This replaces the charging light resistance and the resistors on the bottom of the external voltage regulator.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-23-2009, 05:54 PM | #6 |
Okay, I'm not the sharpest around.... The large red wire goes from the alternator hot post to the regulator plug and terminates? Perhaps you could draw before and after schematics to make this more clear?
05-23-2009, 11:43 PM | #7 | |
Msgt USAF Ret
In the diagram below you will be able to follow this and see where the brown wire from the firewall plug goes to the voltage regulator. The brown wire ends at the voltage regulator and the blue wire takes over and goes to the alternator to the sensing terminal. You still have not answered my question about whether you have an ammeter gauge or an idiot light dash.
