Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-19-2009, 10:34 PM   #1
Vega
'92 4.3 Hot start problems
I have been having intermitment start problems, it only seems to be when it is hot, I have a new Accel distributor, checked everything I can think of the only thing elese it could be is the computer. I have a friend that has a parts '92 w/ 4.3 I am going to try his computer if it is the same. How many different computers were there for the 4.3.
Thanks for your help, Bruce
Vega is offline   Reply With Quote
Old 05-20-2009, 01:48 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: '92 4.3 Hot start problems
Is it a starter problem? Is the timing set to zero? Clean the TBI really good with a cleaner. Run some seafoam through the fuel tank.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-20-2009, 09:15 AM   #3
Vega
New starter, cranks over fine, noid light hooked to injectors does not light then let set for a about an hour it will start.
Timing is set right.
TBI is clean.
New fuel pump and filter, tank clean.
Old 05-21-2009, 10:36 AM   #4
Vega
Well it is not the computer, it would not start this morning and I changed the computer and it still did not start. Let it set for over a half hour and it started. I am getting sick of not having a dependable truck. Any help would be greatly appreciated.
Thanks Bruce
Old 05-21-2009, 10:53 PM   #5
Arad68
Trucks N Tranzams
Arad68's Avatar
It sounds like a loose or intermitant connection somewhere. If it has a firewall connection block, I'd start there.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
