Old 05-25-2009, 10:37 PM   #1
Dark Knight
Dark Knight's Avatar
Need help locating a fuse
I've got an '05 Chevy Silverado. The 12V outlet closest to the driver has stopped working, but the one on the passenger side still does. I found a fuse in the underhood box labeled "CIG LTR". Checked it, and it's good. But, this fuse is for the outlet on the passenger side. I could not find the fuse for the other outlet. Am I just not seeing it or is it labeled differently? (and yes I did check the panel behind the door) Why can't everything be simple like my '67? Why?
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 06-02-2009, 10:43 PM   #2
Dark Knight
Re: Need help locating a fuse
Anybody?
Old 06-03-2009, 08:43 AM   #3
JohnC
JohnC's Avatar
I would think the one fuse would work both of them. You may pull the 12v port out and see if maybe it came unplugged. Could also just be a bad unit. Sorry I can't help you more.
JohnC is offline   Reply With Quote
Old 06-03-2009, 08:10 PM   #4
Josh
He's got mean nasty FANGS!
Josh's Avatar
They are fused separately. I can't remember the name of the fuse off the top of my head but it says something accessory. Most likely it's just blown from a bad cell phone charger or similar.
Josh
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 06-03-2009, 11:14 PM   #5
Dark Knight
There are a few fuses labeled "something" accessory. I'll check them tomorrow. I blew the fuse, that's all I'll say. I'd rather not explain how.
Old 06-04-2009, 08:46 AM   #6
JohnC
JohnC's Avatar
Checked my truck yesterday, and there is a seperate fuse called Aux Power. It is for the Aux power port in the console, or the second one in the dash if you don't have a console. The fuse is in the box in the engine bay. Hope this helps, and sorry I didn't have more info yesterday about it.
Old 06-04-2009, 11:46 PM   #7
Dark Knight
Thanks. Will check tomorrow.
