Old 05-29-2009, 11:43 AM   #1
felixthecatjr
felixthecatjr's Avatar
Low Budget C-10
One day you realize that you need a truck, so then you want a truck. The only thing is that truck must be on a budget. I went on a mini quest to find that truck only to find that a good cheap truck does not exist, or at least not locally. A friend on mine came a across a 1985 C-10, decent shape, needing a lot of TLC. I went to go and take a look at the truck, no motor or trans but the bed floor was solid and the cab was good. After some back and forth with the owner I get the truck for free only if I get the truck off the property before code enforcement arrives, which they where due in 10-15 minutes.
Once the truck was in my possession I need to find a motor and trans fast. The quests to build a cheap motor, again cheap motors are not common. A few dollars later and parts throughout the garage floor a running motor is assembled.
The truck is a decent runner minor tweaking here and there to keep it alive. One day all seems like it is going fine and that faint smell of gasoline; I see no puddle smell goes away months go by until the entire floor under the truck is a lake of gasoline. This is when the fun times begin. Time to install a new tank, not what I wanted to do but it had to be done.
Tank Out
Tank Going in
I did not realize that replacing the tank straps was just a workout.
felixthecatjr is offline   Reply With Quote
Old 05-29-2009, 11:46 AM   #2
felixthecatjr
Re: Low Budget C-10
While the bead was off I figured take advantage and replace the cab corners.
Old 05-29-2009, 11:47 AM   #3
felixthecatjr
Re: Low Budget C-10
Replacing the corners.
Old 05-30-2009, 04:58 AM   #4
st1
st1's Avatar
Re: Low Budget C-10
Nice looks like you got it under control. I bet the code enforcement people was like where did that truck go? past owner what truck?
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 05-30-2009, 12:44 PM   #5
felixthecatjr
Re: Low Budget C-10
Code enforcement still got them on some other minor issues. Once I got the truck up and running I drove by the house and the guy wanted the truck back. Sorry mine now
Old 05-30-2009, 12:49 PM   #6
felixthecatjr
Re: Low Budget C-10
the finishing on the cab corners
Old 06-01-2009, 08:22 PM   #7
evan
evan's Avatar
Re: Low Budget C-10
As good as new!
Evan B.
evan is offline   Reply With Quote
Old 06-01-2009, 09:12 PM   #8
BigRedSled1985
BigRedSled1985's Avatar
Re: Low Budget C-10
never have i been so motivated to purchase an engine lift and a welder!! :p
i haev a few spots like that, plus i know the frame is probably in need to a good once-over, very good (and informative) pics there! good luck on the project!
shaun
1985 C-10 CUSTOM DELUXE
BigRedSled1985 is offline   Reply With Quote
Old 06-01-2009, 10:30 PM   #9
silvereagle07
silvereagle07's Avatar
Re: Low Budget C-10
Nice work, lookin good.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-02-2009, 08:17 AM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Low Budget C-10
Very nice work man! Keep it up..
tvblazer78 is offline   Reply With Quote
Old 06-02-2009, 09:26 AM   #11
jchav62
1962 C-10
jchav62's Avatar
Re: Low Budget C-10
Nice!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-02-2009, 02:58 PM   #12
JohnC
JohnC's Avatar
Re: Low Budget C-10
Nice score man! Looks like a pretty decent project. I would have loved to see the previous owner's face when you went by!
JohnC is offline   Reply With Quote
Old 06-02-2009, 06:25 PM   #13
felixthecatjr
Re: Low Budget C-10
shaun
Thanks, sileragle07
Thanks, tvblazer, your blazer is just bad ass
thanks John,
Old 06-02-2009, 06:43 PM   #14
felixthecatjr
Re: Low Budget C-10
one of the many reasons why I got the truck was that the bedfloor was real nice and solid as compared to some other trucks I have seen in the area.
After some sanding and treating the metal with ospho, then applying POR-15 to the underside of the bed.
Then the frame got the same treatment.
Old 06-10-2009, 02:43 PM   #15
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Low Budget C-10
nice, my truck was a low buck project but it went a little out of hand
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-10-2009, 06:12 PM   #16
felixthecatjr
Re: Low Budget C-10
One section of the bed needed some attention. At the time for some reason I thought the spot was worse it turned out I did more work than was required.
Ospho working it's magic
Old 06-10-2009, 06:16 PM   #17
felixthecatjr
Re: Low Budget C-10
The replacement panel was ok, all replacement panels always need some TLC to make them fit.
Old 06-11-2009, 11:43 AM   #18
evan
evan's Avatar
Re: Low Budget C-10
Sweet! I really need to learn how to weld.
Evan B.
Old 06-11-2009, 12:52 PM   #19
SBTork
Garage wrench
SBTork's Avatar
Re: Low Budget C-10
Your really making this truck something, keep it up.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-16-2009, 08:39 PM   #20
felixthecatjr
Re: Low Budget C-10
Wow it's been a few months since I have posted any updates on the truck, been busy with my other project
So this has kept me busy all summer, can't what to get it done.
So back to the truck, I was sick of looking at my ugly floor, the rubber floor mat was old and falling apart. Then thanks to cash for clunkers the local junk yards are filling up with older Chevy trucks, Ok I am not 100% happy about people getting rid of there trucks but figure I can keep my beast alive as they kill off there's. Any way I got a sweet deal on a new floor mat
The mat was practically brand new and full size as my old one was only half the cab.
My truck never came with a headliner from factory, actually this truck came with zero options.
Having the Florida sun beat on you all day can be painful. So I came across, new to me a headliner for the truck
Ok not very pretty but to me it was a god send. With some prepping, cleaning and black dye
I was on my way to getting a somewhat new interior.
So know I feel as if I have a new truck. Oh yeah still looking for a good seat mine is sort of beat up
I know some of you guys are saying big deal you got some old parts from the junk yard, I know but figure I only sent $30 for the complete headliner, trim pieces included and $20 for the floor mat. Trust me I feel like a king in my truck, well going out to hit a few more junkyards looking for my treasure.
Old 03-07-2010, 03:44 PM   #21
felixthecatjr
Re: Low Budget C-10
After reading a few post on sway bars decided to get one, much improvement. if I can locate a rear bar I would like to install one as well.
Old 03-07-2010, 04:02 PM   #22
54Caddy
GM Addicted
54Caddy's Avatar
Re: Low Budget C-10
did you read the post i had about rear sway bars. apparently the camper special trucks have a stock rear sway bar. Im going to look for one next month for my truck. Low on funds this month or id be hitting up all the pick n pulls and grabbing as many as i can
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-07-2010, 08:52 PM   #23
felixthecatjr
Thumbs up Re: Low Budget C-10
thanks for the info, be on the lookout...
Old 03-07-2010, 11:33 PM   #24
54Caddy
GM Addicted
54Caddy's Avatar
Re: Low Budget C-10
alrite no problem
..Mac’s Garage..
IG:MacsGarage
