Old 01-02-2003, 04:50 AM   #1
BG62
62 GMC Fabricate 350 Transmission Crossmember
I own a 62 3/4 GMC Fleetside longbed
I have the torsion bar front and coil
rear end. I need to fabricate a cross member for my
Turbo 350 tranny. I removed the old 305 engine,Hydramatic transmission.
Installing a 400 smallblock with the 350 turbo tranny I finally located the correct engine mounts but cant get any info for
the Transmission Crossmember.I need help on info of someplace
or someone that can get this Part.It seems that there is no
universal part for these 60-early 62 trucks.This is my first
project, and Im working with a friend.All or any information you can give is thankfull.I live in the Los Angeles area also
so any info on Local shop's or mechanic to contact in the area
would be helpfull.Thanks
bryangreene74@hotmail.com
Also looking for some one to pick up the old motor & trans
its a 305D w\ 3speed Hydramactic tranamision
I think the piston arm broke on engine.the transmission
I was told only needed adjustment for the truck seemed to
slip between first and second gear.but it could also need to be rebulit
BG62 is offline   Reply With Quote
