Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-06-2009, 11:07 AM   #1
M1031
Question Swapping 4.56 for 3.73 ratios
Hi all!
I'm looking to increase my top end on my M1031 by swapping the ratios (45mph in TX bites w/the Mexicans doing 70+). I know I need the carrier bearing (front & rear) as well as the gears themselves. What other parts do I need to swap?
Thanks in advance.
Me.
M1031 is offline   Reply With Quote
Old 06-06-2009, 12:57 PM   #2
rangerfj40
Re: Swapping 4.56 for 3.73 ratios
Get an install kit front and rear. Will have everything you need, minus R&P. Might have to but additional shims to get preload correct.
rangerfj40 is offline   Reply With Quote
Old 09-17-2012, 06:58 PM   #3
1972GMCBOGGER
Have 3.55 carrier for a Dana 60, depending on your rear diff depends if to need a carrier swap. Carrier breaks are typically 4.10/4.56
1972GMCBOGGER is offline   Reply With Quote
