Old 06-06-2009, 07:51 PM   #1
72truckman
72truckman's Avatar
1999 Suburban Bad Acceleration
My 1999 Suburban has been running really badly lately. Changed distributor cap, fuel filter and did the typical maintenance. But, when i floor it off the line it will hold 1st gear at about 4500rpm until i let off of it, then it will shift into second. And, getting to 4500rpm is doggishly slow. It seems to sputter and almost miss. but when i only feather the pedal, it runs great and shifts well. any idea of my problem?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 06-06-2009, 11:00 PM   #2
clinebarger
Re: 1999 Suburban Bad Acceleration
Have you checked fuel pressure? i think the spec is 60-66 psi. check engine light? A plugged catalytic conveter may also cause this problem.
clinebarger is offline   Reply With Quote
