Old 03-24-2002, 01:27 PM   #1
jjg
Post Can someone explain to me how an electic choke works
Hey guys thinking about getting an Edelbrock 1406 with an electric choke? I was just wondering how that really works, would my manifold need an EGR valve or what to run the electrical choke?
thanks
John
jjg is offline   Reply With Quote
Old 03-24-2002, 01:45 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
you dont need egr, you hvae a pre 73 truck, no egr on vehicles prior to 73
electric choke recieves 12 volts from ign switch and the power heats up the heat coil inside the housing and that unwinds it and spins the shaft in there and the rod connected to it runs up to tha choke air valve and slowly opens it, electri choke are quicker and very adjustable and simple to connect and very reliable/.
if you take one off the carb then youll see exactly how it works
good luck
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited March 24, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 03-24-2002, 07:23 PM   #3
Brad69
Crash Test Dummy
Post
From an end user standpoint, the main difference between an elctric choke and a regular one is the elctric one goes from fully closed to fully open in a set amount of time. It takes X minutes, which is adjustable on most. The regular thermostatic choke is dependeant on actual temperature, as it uses engine heat to unwind the bi-metal coil. On cold days, my regular choke can take 15 minutes to go fully open, where an electric choke would be however many minutes I set it to every time.
The more hair i lose, the more head i get.
Build Sheet:
1969 C-10 short fleet
Constructed by taking a 3/4 ton rolling frame from one truck, adding a rust free AC Cab from another, then a bed from another, 1/2 ton front suspension & brakes from another,add in one Goodwrench crate 350, painted DuPont Arctic White,and driven daily.
Brad69 is offline   Reply With Quote
Old 03-24-2002, 07:29 PM   #4
Fast68Chevy
Post
in wihich i consider a plus, cuz them damn bi-metal spring chokes take forever to unwind,...
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
