06-11-2009, 07:39 PM | #1 |
steering wheel play
Is there any way to adjust steering wheel play. Mine seems to have a little bit of play to it. Is it something that can be adjusted or does something need to be replaced?
Grandpas truck, my dream. This is my truck. There are many trucks like it but this one is mine. 65 Chevy C10 Fleetside |
06-11-2009, 07:56 PM | #2 |
Re: steering wheel play
Here is a picture of where the play is at. I hope you can see it ok. Is there anything to adjust on this? Its the part that the rod feeds into.
Grandpas truck, my dream. This is my truck. There are many trucks like it but this one is mine. 65 Chevy C10 Fleetside Last edited by madaca; 06-11-2009 at 07:57 PM. |
06-11-2009, 09:30 PM | #3 |
First I would replace the rag joint. They are available at most parts stores cheap. You just grind the rivits holding the old joint together and pull it apart. You will find that the new one is a LOT stiffer and it will remove a lot of the slop. Then grease all of the front end. The difference in doing these two things should be quite noticable assuming everything else is in decent shape. Otherwise, if the play is in the steering box itself, that can be adjusted. I will let someone with more experience than me explain that process.
D's 63 |
06-11-2009, 09:56 PM | #4 |
Thanks Deryl for the info. It does seem to be in the steering box. Its just a little left and right play. When it passes that one point the steering feels great. I am just hoping that maybe It is something that can be adjusted before i go adding something else to my list of things to buy. I see a nut on top of the box that threads into it but am not sure what that is. I will see if anyone else has any suggestions as well. Thanks again.
06-12-2009, 12:49 AM | #5 |
Resistance is Futile
Loosen the nut on top of the gear box and then tighten the allen shaft going down thru the center. Then retighten the nut. I would make very small adjustments. Also, do the services previously recommended. You should see an improvement in the slop.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-12-2009, 11:40 AM | #6 |
Plus you could consider replacing the bearings in the steering colum. My bearings went out and trashed my colum rod.
Protrash Is your truck still manual steering? |
06-12-2009, 01:02 PM | #7 |
ok, so when I loosen this nut I then back out the bolt that runs down the middle of the nut..right? Mine has a slot in the bolt. It looks like that pulls up the arm that is below the steering box. There is a pretty good gap there. Should I start to feel a difference as I tighten the bolt up? How far is too much? Thanks so much for all the info. First time I ever did anything like this so I want to make sure I do it right.
06-12-2009, 01:15 PM | #8 | |
I have heard many advise against adjusting the preload and mesh.....if there is play it usually means you box is worn out. I have also heard that adjusting it can cause the box to lock up at a very inopportune time....and/or the box will eat its self in a short period of time sounds like a good time to do a power steering swap...
CHEVY ONLY Last edited by joe231; 06-12-2009 at 01:17 PM. |
06-12-2009, 03:49 PM | #9 |
Didnt know that stuff, Joe!!!!!! Damn your getting technical....these trucks are supposed to be easy to work on! I wasnt trying to get madaca off in the weeds, Ive tightened them a little bit to get rid of some slop...it's not a total fix by any means. My buddy did it and he locked his column up and almost wrecked.
06-12-2009, 05:12 PM | #10 |
I think I will just need to replace my steering box sometime in the next couple of months. Maybe I can find a used one around here somewhere and get it sooner. Thanks for all the help everyone.
06-12-2009, 06:37 PM | #11 | |
say it with me "POWER STEERING"
CHEVY ONLY |
06-12-2009, 08:21 PM | #12 |
how much would power steering set me back?
06-12-2009, 09:58 PM | #13 |
I think the high dollar part is the gear box. If you can find a truck being parted or in the wrecking yard you'd be off and running. Then depending on your engine, how to mount the pump.
06-13-2009, 12:18 AM | #14 |
yeah the REZ conversion kit is $59.95 plus shipping (classic parts has cheap shipping)
http://www.classicparts.com/1960-66-...ctinfo/76-979/ then you need a gearbox from one of the following: 73-87 2wd pick-ups, 73-91 2wd burbs, 73-91 2wd crew cabs, 73-91 2wd blazers along with the pitman arm and pump with brackets to fit your engine.....I believe 1980 is when they GM switched to the metric fittings on the pump and gearbox....my '80 is metric anyway....if you have a local pick and pull yard you should be able to get the stuff pretty cheap
CHEVY ONLY Last edited by joe231; 06-13-2009 at 12:19 AM. |
06-13-2009, 01:56 PM | #15 |
Thanks for the info. I do have a u-pull-it place close buy. I was out there a couple of weeks ago and they have a lot of old trucks out back. I will make another trip for this conversion when I get some cash. Is it pretty easy to do? I have the 283 v8 engine.
06-13-2009, 02:03 PM | #16 |
I thought it was easy. The hardest part is cutting and re-welding the steering shaft. The rest bolts on. You also need to check the heads on your engine for accessory bolt holes. The early small blocks didnt have them, but they can be drilled and tapped for them.
I think Joe231 has pics of the early style power steering pump brackets. I'm only familiar with 69 and up.
06-13-2009, 11:08 PM | #17 |
I agree with protrash, it ain't a big deal...and most everyone that has done it wishes they would have done the conversion first before anything else.
I assume you have a short water pump and the heads with no accessory holes...there are a few ways to go with the brackets for the pump and your engine. I got some factory brackets from Captainfab. I will try to find some pics. I know LILRED66 (Tony) had several sets of the brackets...or if you google short water pump power steering brackets (or sbc swp power steering brackets) there are some cool ones out there for sale. Good luck!!
CHEVY ONLY |
06-14-2009, 06:57 PM | #18 |
After tightening my steering wheel down today the play in the steering seems to have got much better. I had stripped the threads in the steering shaft and had to rethread it in order to get my steering wheel tightened down nice and good. I will still be looking to upgrade in the future though. Thanks for all the help
07-21-2009, 09:41 PM | #19 |
do you guys know if that bracket from rez will work on a 67 that has the hydrualic assist and i want to upgrade to a 72 integral setup. thanks
