Old 06-15-2009, 04:20 PM   #1
DC_Jimmy
Largest Tire/Wheel on Stock 4x4 suspension
Want to hear your thoughts on the largest tire/wheel combo possible on stock '71 Jimmy 4x4 suspension without cutting fenders? What offset on the wheels? Seems I've seen some in magazines claiming they run 33x12.50s on stock wheels...
DC_Jimmy is offline   Reply With Quote
Old 06-15-2009, 04:32 PM   #2
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: Largest Tire/Wheel on Stock 4x4 suspension
here is a pretty good thread on tire sizes
http://67-72chevytrucks.com/vboard/s...d.php?t=182417
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-15-2009, 04:34 PM   #3
RLONG
RLONG's Avatar
The 33/12.50 would be like the old 16.5/1200 from what i remember you would have to trim the front horns. I think 31 or 32 were the biggest without trim maybe a 11-15 possible.
RLONG is offline   Reply With Quote
Old 06-15-2009, 07:52 PM   #4
BLUE THUNDER
BLUE THUNDER's Avatar
I do have a 33x12.50-15 bfg all terrain on a stock 15" wheel, but it was difficult to balance. The tire is bulging on both sides. I have it as a spare. As far as that tire size, you can fit them w/o claerance issues. My 33's are mounted on 12x10 inch wheels. Highly recommend that wheel size. Here are a couple of pics. Later.
BLUE THUNDER is offline   Reply With Quote
Old 06-15-2009, 10:42 PM   #5
teamradrz1
teamradrz1's Avatar
I had 32s on my stock 72 blazer and they were perfect.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 06-16-2009, 10:17 PM   #6
DC_Jimmy
Blue Thunder-You highly recommend 12x10 wheels. I'm assuming you mean 15" diameter wheels, 12" wide or 10"? Your Blazer certainly has a good stance. Have you had your springs refreshed or using add-a-leafs or perfectly original suspension?
Old 06-16-2009, 11:22 PM   #7
BLUE THUNDER
Yup you're right. I meant 15x10 wheels. Fat fingers little keys, what can I say. As far as the Blazer, that's how it looked w/o any lift. No add-a-leaf or re-arched springs. I just put a 4" lift on and this is what it looks like now with 33x12.50-15 on 15x10 wheels.
Old 06-17-2009, 01:18 AM   #8
OldCreek
OldCreek's Avatar
Looks Healthy!!!
Thanks for the before and after...it helps guys like me trying to figure out how much lift, etc.
You don't seem to have any rear end squat... what company springs did you buy?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-09-2009, 03:08 PM   #9
DC_Jimmy
Thanks for the feedback guys. I finally have my Jimmy down on stock suspension. The 33x12.50s have not rubbed at all, though they are worn quite a bit. Probably go with 32s when I have to buy a new set
Old 07-10-2009, 04:33 AM   #10
vtblazer
vtblazer's Avatar
This is an age old debate that IMO boils down to how you plan on using your truck.
33's on stock suspension works okay for the street, not so much on the trails though.
One of the best combo's/fit with a 33, is to use the ever popular rally wheels that came stock on the next gen trucks.
vtblazer is offline   Reply With Quote
4x4, tire size
