Old 01-03-2003, 01:38 PM   #1
nate68
rear disc caliper pic
here is a pic of the caliper from my rear disc setup. it's not the best pic but oh well. i also have a pic of my adjustable proportioning valve if anyone wants to see that
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 01-03-2003, 11:59 PM   #2
UNCLEBOB
I would like to see your proportioning valve. I just finished installing 9" disk brake rearend and have to install proportioning valve also. Also how did you hookup emergency brake cable? Thanks
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears
UNCLEBOB is offline   Reply With Quote
Old 01-06-2003, 02:00 PM   #3
nate68
i am using the regular proportioning valve from an 82 1/2 ton because i did the 73-87 front suspension swap.
Old 01-06-2003, 06:57 PM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
What info do you have about the rear brakes? Was it a kit? What parts? How was the install?
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 01-08-2003, 09:16 PM   #5
Rastus
I'm also wondering about this setup.
Does it work better?
93' 1500 Silverado Ext. cab Fullsize bed.
Dual exhaust with Chrome tips, Exiting at the rear.
Rastus is offline   Reply With Quote
Old 01-09-2003, 01:22 AM   #6
nate68
79 lincoln mark V rear end. you have to weld new saddles on the rear end, use an adjustable panhard rod (from early classic), shorten driveline, new brake hoses (i chose braided stainless, earl's) mid 70's corvette master cylinder, 3/4 ton booster.
