Old 03-24-2002, 04:02 PM   #1
boilrman
70 Chevy 3/4t
Angry Oil on Dampner
I have a newly rebuilt 250 I6 and have almost 600 mi on it. I was under the hood the other day and noticed oil covering most of the dampner. It looks to be on the front side only. My guess is it is coming down the crankshaft past the keyway. Should I have put some permatex gasket maker in there before assembly? It is newly painted and rebuilt and I really want to try and keep it clean as long as possible. It's not a show truck by any means, but just wanting to try and keep things clean.
Any ideas on this?
1971 Chevy 1/2t, 350 -- SOLD
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6(freshly rebuilt), 4 speed
Keokuk,IA
http://communities.msn.com/SchweringFamily/shoebox.msnw
MSN Messenger = boilrman
Find a job you love and you'll never have to work a day in your life.
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 03-24-2002, 04:57 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
some black rtv on the corners of the pan where the front pan rubber seals meet in the corners is good to have
Fast68Chevy is offline   Reply With Quote
Old 03-24-2002, 05:15 PM   #3
69 longhorn
Post
You could have oil wicking down the keyway....I would pull the balancer bolt,& clean everything with brake cleaner,then use a little RTV& tork it back up.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-24-2002, 07:20 PM   #4
71402BB
now thats a true COON DOG
Thumbs up
You could also try same oil seal fattener. What it dose is it fattens the all your oil seals to help stop leaks. If it's not a big leak then this should work. I would first try doing what the others members mentioned first!
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 03-24-2002, 07:33 PM   #5
704x4
Post
just a guess (not saying it is) is it power steering fluid
many small blocks start leaking power steering fluid and it makes it to the damper
you probably know if its oil but i thought id through that in
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
