06-20-2009, 09:54 PM | #1 |
Wheelbearing and hub removal
Hi is it possible to remove the wheel bearing and hub assembly on a 2004 chevy two wheel drive or are the pressed in.If you can do you just bang them out or do you need some kind of puller. Thank you 8bolt.
06-21-2009, 02:35 PM | #2 |
Re: Wheelbearing and hub removal
front or rear?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-21-2009, 03:41 PM | #3 |
I think the 99 and newer truck use a slip on rotor and the bearing/hub is a sealed assembly and is serviced as a whole.
Here is a pick of the assy: http://www.summitracing.com/search/?...d=515054&dds=1
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
06-21-2009, 11:45 PM | #4 |
Yep, much easier to service that way. I always get my hubs from the salvage yard they are usually cheap.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
