Old 05-17-2002, 07:46 PM   #1
Dave66!
Question Spring eye bolt removal ???
Ok Im in desperate need of a good trick.it took 4 sawzall blades to get one front spring of my blazer.I put a set of ranchos on a jeep before and burned the bushings out with a torch but these dont seem to want to burn any suggestions will be greatly apreciated
1972BLAZER,1966C10SWB,1963NOVASS
HOLIDAY,IL
HOLIDAY,IL
Dave66! is offline   Reply With Quote
Old 05-17-2002, 07:54 PM   #2
Zkast
Zkast's Avatar
Post
If you can locate new bolts, just cut the head and threads off and slide the spring out.
Pictures and more...
Email me
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Garrett
Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-17-2002, 08:04 PM   #3
Dave66!
Post
thanks ive got new bolts(nla from gm but i found some at an international big ol truck dealer)cutting grade 8 bolts is a real bear unless there is some kind of diamond tip sawzall blade im not aware of.
HOLIDAY,IL
HOLIDAY,IL
Old 05-17-2002, 08:11 PM   #4
Zkast
Zkast's Avatar
Post
I was meaning, use the torch to cut the head/thread then slip the spring out. Manual labor isnt good!
Email me
'71 LWB
350/350T, PS/PB
Garrett
Olathe, Kansas
Old 05-17-2002, 08:18 PM   #5
Ed ke6bnl
Post
I have had good success cutting harden bolts with a die grinder or 4 1/2 angle grinder and a cut off wheel. Torch sure will do it as well Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
Sorry 50 F1 pu
Sorry 63 Ford Econoline pu
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 05-17-2002, 08:25 PM   #6
Dave66!
Post
ill probably try the cutoff wheel tomorrow but im scared to get the torch that close to my shackles ive had to many WOOPS! with the torch before
thanks
HOLIDAY,IL
HOLIDAY,IL
Old 05-19-2002, 01:43 AM   #7
t korinek
Truckin' Krazy
t korinek's Avatar
Post
I have used a skil saw with a metal cut off wheel(cheap at a hardware store) to remove spring bolts in the past, it worked much better & faster than a sawzall. If there's room for it. Good luck
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
