Old 07-11-2009, 09:26 AM   #1
GR82BME
GR82BME's Avatar
HELP!!! 62 front suspension.
I just got back my front cross member and upper a-arms back from the power coater, it was donated from a 79 chevy truck. I thought before I remove the torsion bars and the rest of the front suspension I would measure it, and it appears to be 1/4 to 3/8" gap for each side. Is this the way it is suppose to be? do you have to use any spacers to fill in the gap? Any pictures or advice would be greatly appreciated. I live in Broken Arrow Oklahoma if any one is thursty for a beer and want's to see what I have going on.
Thanks Derek
GR82BME is offline   Reply With Quote
Old 07-11-2009, 09:49 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: HELP!!! 62 front suspension.
I havent done this conversion, and I'm not familiar with doing it on a '62. I know some people have really had to wrestle the frame rails around to get that thing in. Others it sits in perfectly. I would check your frame for square and make some marks/measurements before disassembly.
I dont see why a spacer would make any difference once the whole assembly is bolted in and tightened up. Maybe just a little more effort for drilling.
Good luck and keep us posted.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-11-2009, 09:56 PM   #3
Captainfab
60-66 Nut
I've not done the crossmember swap on a '60-'62 either, but it seems like some guys have had to pull the frame over to bolt up to the crossmember. This was because the frame had sprung in when the old crossmember was removed.
Old 07-12-2009, 11:57 AM   #4
tonythezeek
tonythezeek's Avatar
hmmm i dont know. I have a 62 and did the crossmember swap about a year ago with a crossmember from ether a 75 or a 79 (cant remember which one.. looked at sooo many parts and have had sooo many beers since then). I really dont remember if there was a huge gap but i did notice that there was a little bit of space between the frame rails and crossmember. I didnt think too much of it at the time...but now i'm wondering...
...<sigh> maybe i should save up and buy a Porterbuilt?
tonythezeek is offline   Reply With Quote
Old 07-13-2009, 09:29 AM   #5
GR82BME
GR82BME's Avatar
So when tightening the bolts, you just pulled the frame out to the cross member? Well I have everytning disconnedted from the engine and tranny, so I will be pulling that tonight, along with the front suspension, so I guess I will see what is going on then. Thanks for the help guys
Old 07-13-2009, 11:50 AM   #6
joe231
joe231's Avatar
so your frame is narrower than your cross member?
I think after you tighten it is should be fine, the is only 3/16th's on each side.....I have heard of people having the opposite problem...the frame was wider than the cross member and they had to compress the frame to get it in the member....
CHEVY ONLY
Old 07-13-2009, 12:52 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: HELP!!! 62 front suspension.
GR82BME,
Do you have a picture of your front end, and tell me all what you have done so far. Let me see a front view of the setup, and that crossmember.
I have a Mustang II IFS Clip on my 62.
Thanks,
Big "B"
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Chevy Truck Trailing Arms & Crossmember Kit, 1960-1972
Replacement Trailing Arms & Crossmember
For Lowered Trucks Only
For Coil Spring Rear Suspension Only
Bolt-In Installation
Works With One Or Two Piece Driveshafts
http://www.ecklerstrucks.com/product...4&dept_id=1828
1962 Stuff
http://www.chevychevy.com/pages/62_Chevy.htm
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-13-2009, 02:28 PM   #8
GR82BME
GR82BME's Avatar
I have some with the motor in, and hopfully after tonight I will have some with the motor out. I will try and post some pic's then. Its been awhile since i posted pics, so I will have to remember how to do that.
Old 07-13-2009, 02:44 PM   #9
1Bad62Pro/Street
Sounds good Bud!
Old 07-13-2009, 07:55 PM   #10
GR82BME
GR82BME's Avatar
I havent loaded pictures in a while so I hope this works
Old 07-13-2009, 07:59 PM   #11
GR82BME
GR82BME's Avatar
Well since that seemed to work I thought I would load up a few more
Old 07-13-2009, 08:02 PM   #12
GR82BME
GR82BME's Avatar
Oh, ignore the date, I'm stupid when it comes to electronics
Old 07-13-2009, 08:14 PM   #13
1Bad62Pro/Street
I am looking on my Blackberry. So is that a front clip of a later model chevy? Or am I seeing wrong. Everythings minimized on my screen.
Old 07-13-2009, 08:59 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
Following is a link to details of the install on my 1960. After recently replacing the power steering box I'm convinced the donor front end came out of a 1975 rather than a 78. I did the swap 10 years ago so I don't remember the frame having a gap either way. Seems mine was tight and I needed a cheap cable puller to pull it into position. Good luck.
http://sixty7ss.proboards.com/index....lay&thread=633
Old 07-13-2009, 09:22 PM   #15
1Bad62Pro/Street
markeb01,
Cool front end swap! Nice Thread post on the swap! I wished I had more pics of my IFS swap, but wasn't thinking at the time.
Old 07-13-2009, 11:19 PM   #16
Captainfab
60-66 Nut
Well all I am seeing here is your original suspension installed. Do you have any pics of the new suspension crossmember installed and the gap in question?
Old 07-13-2009, 11:22 PM   #17
Captainfab
60-66 Nut
Nice writeup on the swap. Thanks for sharing that.
Old 07-14-2009, 08:51 AM   #18
GR82BME
GR82BME's Avatar
I haven’t installed the new suspension yet, I was just doing so measuring and saw that there was a difference in the dimensions
Old 07-20-2009, 09:26 AM   #19
Oklahoma
can anyone tell me where to locate the shock's after the new cross member has been installed? some pics would be great. Thanks
Oklahoma is offline   Reply With Quote
Old 07-20-2009, 09:51 AM   #20
joe231
joe231's Avatar
what year?
I know the 63-66 shocks mount to the frame like the 67-up trucks, are the 60-62 shock mounts different?
CHEVY ONLY
Old 07-20-2009, 09:55 AM   #21
Oklahoma
yea, its a 62, I changed out the cross member for a newer style and I can tell where the shock mount on the frame will be in the way of upper a-arm, or at least it seems it will
Old 07-20-2009, 12:40 PM   #22
joe231
joe231's Avatar
sorry, my knowledge and experience with the '60-'2 frames is very limited....some one on here will know though....
And, from a fellow Okie....be sure to check out the Oklahoma section, there is a link to it in my sig
CHEVY ONLY
Old 07-20-2009, 05:18 PM   #23
Revin68
Recreational Grease Monkey
Revin68's Avatar
Torsion bar frames are indeed narrower. They also use a different front bumper because of this. I will be doing this same swap on my 60 and plan on using plate as spacers, equal amounts on both sides to fill as much of gap as possible. I'm in Midtown and would love a beer =) PM me and we'll figure it out.
Thanks,
Robert
Thanks,
Robert
60' Chevy Stepside SWB
08' HHR SS 260hp
Revin68 is offline   Reply With Quote
Old 07-21-2009, 07:59 AM   #24
Oklahoma
Hey thanks for the info, after I put the cross member up on the rails the difference wasnt that much, about a 1/8" on either side, so I just pulled it together. One thing I did notice is that 8 holes will have to be redrilled.
